F20B FAQ
Old Jun 19, 2007 | 07:02 AM
Bense's Avatar
Default F20B FAQ
F20B
Accord/Troneo Sir and Sir-T (CF4) (JDM)
197hp@7200/145tq@6600
85mm bore
88mm stroke
145.5mm rods (f20b rod length = 145.425)
1.65 r/s ratio
55mm mains like h22a4 block
rod journal has been offset ground on both sides to the size of a b-series rod journal.
11.0:1cr
smaller, b-series rod journals
beefy rod, like a s2000
23mm wrist pin
exhaust manifold = H22
intake manifold = h22
dizzy = h22
timing belt = unique, uses 156 teeth, you can use a h22 one. (see below)
waterpump = h22
Oil Pan = F23
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeikDiesel &raquo;</TD></TR><TR><TD CLASS="quote">
Belt that came with my f20b from h-motors
14400-PCB-004 Teeth count 156
New H22 timing belt part number
1400-P13-003 Teeth count 155</TD></TR></TABLE>
Engine is a mix between the H22A4 and F23
Misconceptions about the F20B:
1. It does NOT come with a single stage intake manifold. That is found on the H22A7 European Accord type R. For everything that you'd ever want to know about that intake manifold click here:
https://honda-tech.com/zerothread?id=1960750
2. It does NOT have type S cams. It is believed that it has the same cams that are found in the JDM H22.
EDIT, 09/11/07: Manual version has type S cams, Auto Version has regular H22 Cams
3. Most engines will be from the automatics which have a smaller tb and weaker camshafts.
F20B Dizzy wiring
https://honda-tech.com/zerothread?id=1957852
Specs of other honda ~2 literish engines for comparison
B20Z = 146hp, 133tq
F20B = 200hp, 145tq
F20C = 240hp, 163tq (JDM)
K20R = 220hp, 158tq (JDM)
H22A = 200hp, 161tq (JDM)
H22S = 220hp, 163tq (JDM)
H23A = 160hp, 156tq
H23VTEC = 197hp, 163tq
k20a2 = 200hp @ 7400, 142tq @ 6000
A few random pics of F20Bs that I've found
A few pictures I took of a F20B
More info to come
Old Jun 19, 2007 | 02:17 PM
HeikDiesel's Avatar
Default Re: F20B FAQ (Bense)
Some water pump and timing belt info.
Water pump part number
19200-P13-003 (Comes with mounting o-ring)
Only ID numbers that I was able to find on both the new and the old pump was "26T P13"
Modified by HeikDiesel at 11:36 PM 6/19/2007
Old Jun 19, 2007 | 05:11 PM
Bense's Avatar
how many teeth are on those belts?
Old Jun 19, 2007 | 05:54 PM
SIXTY's Avatar
Default Re: (Bense)
Are the sleeves iron or frm?
Old Jun 19, 2007 | 07:18 PM
HeikDiesel's Avatar
Default Re: (SIXTY)
Iron sleeves, Ill count the teeth tonight
Edit....I was very wrong. Old belt has 156 teeth, new has 155 Fixed info
Modified by HeikDiesel at 11:33 PM 6/19/2007
Old Jun 21, 2007 | 01:17 PM
skunked's Avatar
Default Re: (HeikDiesel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeikDiesel &raquo;</TD></TR><TR><TD CLASS="quote">Iron sleeves, Ill count the teeth tonight
Modified by HeikDiesel at 11:33 PM 6/19/2007</TD></TR></TABLE>
you sure about that? I could have sworn they're FRM.
Old Jun 21, 2007 | 01:50 PM
HeikDiesel's Avatar
Default Re: (skunked)
Not sure, but everything I read said there were iron. Any way to check that skunked?
Old Jun 21, 2007 | 02:06 PM
Bense's Avatar
jdogg will know. he's got one of these things sitting right beside him every time he gets online
Old Jun 21, 2007 | 02:22 PM
HeikDiesel's Avatar
Default Re: (Bense)
Well I have mine sitting right here...how would I check it? Magnet?
Old Jun 21, 2007 | 02:45 PM
skunked's Avatar
I'm almost positive it's FRM. If they were Iron those blocks would be gold, and they're not
Old Jun 21, 2007 | 03:30 PM
HeikDiesel's Avatar
not saying everyone is right skunked but they are saying iron across the board
Old Jun 21, 2007 | 03:31 PM
skunked's Avatar
Your right, it's a small bore (85mm) Iron sleeve. I was thinking type S
Modified by skunked at 4:55 PM 6/21/2007
Old Jun 21, 2007 | 03:55 PM
mgags7's Avatar
Nobody mentioned it, but the valves are B series size in a head that is otherwise very similar to the H22 head.
Matt, he's right, the sleeves are iron, no frm here.
Old Jun 21, 2007 | 04:43 PM
HeikDiesel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">Your right, it's a small bore (85mm) Iron sleeve. I was thinking type S
Modified by skunked at 4:55 PM 6/21/2007</TD></TR></TABLE>
Cool I was right for once lol
Old Jun 22, 2007 | 06:54 AM
ImportechPerformance's Avatar
So just to clear some issues up on another forum. On the F20b's does it actually have that stamped on the block (I believe they do)? Or does it still have H22 stamped (which makes no sense to me).
Gracias!
Old Jun 22, 2007 | 08:53 AM
Bense's Avatar
Default Re: (ImportechPerformance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportechPerformance &raquo;</TD></TR><TR><TD CLASS="quote">So just to clear some issues up on another forum. On the F20b's does it actually have that stamped on the block (I believe they do)? Or does it still have H22 stamped (which makes no sense to me).
Gracias!</TD></TR></TABLE>
Just be like "PWNED BY THE IMG"
Old Jun 22, 2007 | 01:12 PM
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">Just be like "PWNED BY THE IMG"
Ahhh! I knew it!
Old Jul 17, 2007 | 01:24 PM
Bense's Avatar
just added a link to the f20b dizzy wiring schematics
Old Jul 17, 2007 | 03:36 PM
atlplayer4life90's Avatar
hey on the back of the block there is a neck for a hose near the water pump where does that go on the car, sorry i dont know how to add a picture if u could help with that also thanks
Old Jul 17, 2007 | 03:47 PM
skunked's Avatar
Default Re: F20B FAQ (atlplayer4life90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atlplayer4life90 &raquo;</TD></TR><TR><TD CLASS="quote">hey on the back of the block there is a neck for a hose near the water pump where does that go on the car, sorry i dont know how to add a picture if u could help with that also thanks</TD></TR></TABLE>
off the water tube? It goes to the heater core.
Old Jul 17, 2007 | 04:05 PM
Default Re: F20B FAQ (skunked)
thanks skunked for the help any idea on what i do about a dist. i have a obd2b ek and a obd1 h22
Old Jul 17, 2007 | 04:06 PM
and the upper plug above the oil filter that is the knock sensor right
Old Jul 19, 2007 | 06:44 PM
Loco-B's Avatar
bump for the awesome info!
i'm putting one into my CD7 as we speak!
Old Jul 26, 2007 | 03:47 PM
XES's Avatar
XES
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">Misconceptions about the F20B:
I am going to have to disagree with this comment. I have had 2 F20B motors and am currently using the F20B cams in my car. I spec'd them and also degreed them in the past. They match up IDENTICAL to the H22 Type S cams listed on the Crower site.
http://www.crower.com/cat/impo...shtml.
Normal JDM cams have the same lift, etc as normal USDM cams. I have dynoed both cams on my motor and F20B cams have much more lift and different duration and ramp angles than normal H-series cams. Here was my dyno comparison: http://www3.telus.net/public/unrynhen/camdiff.jpg
Old Jul 26, 2007 | 05:34 PM
HeikDiesel's Avatar
Default Re: F20B FAQ (XES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XES &raquo;</TD></TR><TR><TD CLASS="quote">
Normal JDM cams have the same lift, etc as normal USDM cams. I have dynoed both cams on my motor and F20B cams have much more lift and different duration and ramp angles than normal H-series cams. Here was my dyno comparison: http://www3.telus.net/public/unrynhen/camdiff.jpg</TD></TR></TABLE>
Im curious as to what size TB's are on both of those engines
