Are spoon/vision mirrors for eg/dc/ek exactly the same but use different bases/backings
Old Jun 19, 2007 | 04:47 AM
6SPD_EK's Avatar
Default Are spoon/vision mirrors for eg/dc/ek exactly the same but use different bases/backings
ok story - in full I am going to have some kevlar mirrors made & need to know if spoon / vision mirrors are identical between eg/dc/ek & just use different bases to attach to the different chassis door's?
can the bases or mirror internals be purchased separately anywhere?
Old Jun 19, 2007 | 02:07 PM
enkeirp02's Avatar
Default Re: Are spoon/vision mirrors for eg/dc/ek exactly the same but use different bases/backings (6SPD_EK
If you really want to know!.. Vision manufactures the mirrors for both spoon and vision. The first gen mirror housings and base were made of abs plastic, the mirrors them selves were NOT blue tinted and they had a rubber lining that went around the actual mirror. The second gen mirrors are different, they now come with the same abs plastic base but have carbon fiber mirror housings. In addition the second gen mirrors are now a blue tint and do NOT have the rubber lining around the actual mirror.
The mirrors and mirror housing are the same across the different chassis. As far as the bases go, i believe that the EK, EG and DC2 have different ones because of the changes in the mounting pattern.
I could be incorrect regarding the bases, can someone confirm?
With respect to the bases and mirror internals, I am sure you can contact one of the companies that make the knock-off mirrors and ask for the contact info on the company that actually does the manufacturing. With a big enough order I am sure you can work out a deal with the manufacturer where you can order the bases and internals in bulk. However, if you are making only one, you are better off going on ebay and purchasing one set of the knock off mirrors and using the parts you need.
Old Jun 19, 2007 | 02:08 PM
Nate047's Avatar
all your base are belong to us
JK seriously tho, some one help the man out...
Old Jun 19, 2007 | 02:50 PM
opiumdaze's Avatar
from my experiences with dc and ek mirrors... they are both the same! (ive only dealt with spoons) but reading the above i guess its the same thing
Old Jun 19, 2007 | 03:17 PM
NIKE SB'd's Avatar
From personal experience EG/EK/DC2/DC5 are all the exact same mirror w/ different plates.
Old Jun 19, 2007 | 10:45 PM
enkeirp02's Avatar
Default Re: (NIKE SB'd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NIKE SB’d &raquo;</TD></TR><TR><TD CLASS="quote">From personal experience EG/EK/DC2/DC5 are all the exact same mirror w/ different plates. </TD></TR></TABLE>
Well its confirmed, each chassis has a different mounting plate.
Old Jun 20, 2007 | 04:00 AM
6SPD_EK's Avatar
Default Re: (enkeirp02)
thanks doods.... time to start making the carbon/kevlar ones then
Old Jun 20, 2007 | 03:40 PM
teamsol's Avatar
Default Re: (6SPD_EK)
how are you going to make the kevlar mirrors, ive always wanted a set but in the vision type dc style
model x
Jan 19, 2003 07:15 AM
chrisir19
Dec 25, 2002 07:59 AM
ITRinEJ1
Mar 5, 2002 12:51 AM
Yellow Dragon
37
Feb 24, 2002 06:41 PM
kefka
Jan 15, 2002 06:45 PM
