steering wheel shaking
Old Jun 18, 2007 | 11:32 PM
cam003's Avatar
Default steering wheel shaking
O.K. I have a 95 GSR 150k miles, and on stock susp, with the exception of eibach prokit springs. My steering wheel is shaking at pretty my all speeds now. I am ordering new struts front and rear, drop zone they are cheap and I have heard they ride just as good as stockers. I know they are weak but I am not into crazy performance any more.
Any other suggestions? Should I order tie rod ends and ball joints too?
All input is greatly appreciated, please no negative criticism. I don’t post very often and I have found this place to be the most helpful for about 7 years now. Thanks again.
Old Jun 18, 2007 | 11:33 PM
numbnuts22715's Avatar
dont order anything until you take a look at it.
You may juts be wasting your money.
Have you gotten an alignment lately? that could be a majority of your problem.
Old Jun 18, 2007 | 11:36 PM
cam003's Avatar
Default Re: (numbnuts22715)
struts already comming, but they have 150k on them so i know i need them anyways. thanks
Old Jun 19, 2007 | 12:06 AM
littlejj26's Avatar
if i were you, i would check your axles. my DA is doin the same and i ordered some. it was worth the $150
Old Jun 19, 2007 | 02:00 AM
OC Geezer's Avatar
Default Re: (littlejj26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littlejj26 &raquo;</TD></TR><TR><TD CLASS="quote">if i were you, i would check your axles. my DA is doin the same and i ordered some. it was worth the $150 </TD></TR></TABLE>
I agree, check out your axles and alignment first. if it happens when you're braking it might be your brakes too.
Old Jun 19, 2007 | 09:47 PM
cam003's Avatar
do the axels get out of ballance? they are 12 years old and have never been changed
Old Jun 19, 2007 | 10:04 PM
roastbeefrichie's Avatar
Default Re: steering wheel shaking (cam003)
could be your tires or your alignment. i would check your tires to see if there are any flat spots or uneven wear. it could simply be that your wheels are out-of-balance. any these things can cause static imbalance which would be causing you wheel to shake.
if your suspension is shot, this could be detrimental to the life of your tire.
Old Jun 19, 2007 | 10:10 PM
SleeperGSR's Avatar
Default Re: steering wheel shaking (roastbeefrichie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roastbeefrichie &raquo;</TD></TR><TR><TD CLASS="quote">could be your tires or your alignment. i would check your tires to see if there are any flat spots or uneven wear. it could simply be that your wheels are out-of-balance. any these things can cause static imbalance which would be causing you wheel to shake.
if your suspension is shot, this could be detrimental to the life of your tire. </TD></TR></TABLE>
steering wheel shake is usually tires out of balance. Try this first cheap, like 7 bucks a tire. After that get an alignment. Did you sprinds lower your car? It would create negitive camber. And broken suspension will kill a tire in a few thousand miles.
uVTECiVTEC
Jul 23, 2010 02:09 PM
lildragon'07
13
Jun 2, 2010 08:31 AM
turbogirl84
Nov 10, 2007 01:09 PM
THC07
Apr 11, 2007 07:23 AM
redlineintegra
May 19, 2006 11:45 PM
