Steering wheel problems, input needed.
Old May 19, 2006 | 10:25 AM
redlineintegra's Avatar
Default Steering wheel problems, input needed.
I've been having shaking problems in my steering wheel above 90km/h, and have fixed all the usual culprits: lower balljoints, front wheel bearings, axles, checked alignment and tire balancing. The other day I noticed that I can move the steering wheel 1cm or so, if you hold it like you check a wheel for loose bearings. I have yet to check the 19mm nut for tightness, but is there any other reason the wheel would be loose, or shake above 90km/h like that? Info appreciated.
Old May 19, 2006 | 01:32 PM
jay_96teg's Avatar
Default Re: Steering wheel problems, input needed. (redlineintegra)
check your steering column bolts. there are bolts that hold the steering shaft to the dash frame. also check your steering wheel bolt, remove the t30 screws on the side of the airbag and check the mounting bolt.
Old May 19, 2006 | 11:45 PM
Default Re: Steering wheel problems, input needed. (jay_96teg)
Steering wheel problem fixed, turns out somehow the 19mm backed off .. still have the high speed shake/vibration to figure out.
^^ gökan^^
Suspension & Brakes
Jan 31, 2010 11:53 AM
Ldo
May 26, 2009 03:49 PM
kumar*
Dec 23, 2008 10:32 AM
ketchup
12
Aug 26, 2008 12:30 PM
AGNSoncite
Nov 14, 2003 01:03 PM
