The R is runing like ass!
Old Jun 5, 2002 | 02:40 PM
YellowSpeed's Avatar
New User
Default The R is runing like ***!
What would cause this to happen? When I hit 2 to 3 thousand RPM my cars start to lag like it has no power. When I'm in third gear it like there is no power, when I hit Vtech it is kind of mild. I have a VAFC in the car but it is set to stock setting. When I took my car to the Dealer today they said my car was running to rich and the my Spark plug need to be change and if I change them and got rid of the VAFC my car would be back to normal. Would the spark plug cause my car to run that bad. I going to change the plug tomorrow so I find out if it is that.
Old Jun 5, 2002 | 02:42 PM
Big Phat R's Avatar
Default Re: The R is runing like ***! (YellowSpeed)
Did you use crimpable connections when using the V-AFC?? If so - get rid of them and solder everything.
Old Jun 5, 2002 | 02:58 PM
PM-Performance's Avatar
Default Re: The R is runing like ***! (Phat Bastard)
im betting the vafc is the problem , either bad tuning or bad install . esp since they said about the fuel
another thing that can do that though is the o2, but they prob would have caught that
Old Jun 5, 2002 | 03:01 PM
shirubia's Avatar
Default Re: The R is runing like ***! (itr206)
I had a similar problem in my gsr!!!
did you remeber to set the correct settings in the etc menu?
Old Jun 5, 2002 | 03:10 PM
New User
Default Re: The R is runing like ***! (shirubia)
I forgot to put when I was at the dealer they check the O2 and it was fine. The fuel setting are set to 0 on the VAFC. The VAFC has been in the car a good while but for the past week and a half my car has ran like *** and as each day passes it get worse.
So you think if I take out the VAFC or maybe get it tuned the car will run fine.
Old Jun 5, 2002 | 03:47 PM
Chubz's Avatar
no make sure that your sensor setting on the vafc is 6 in and 6 out, and that the throttle is at 10%low and 50%high. And that the throttle setting is 4 with the arrow pointing up.
Old Jun 5, 2002 | 04:07 PM
Todd00's Avatar
I said I don't want a title!
Without a doubt it is the vafc. Check all connections because my car went into open-loop mode and started dumping fuel into the motor when a connection on my sfc-vtec came loose.
Old Jun 5, 2002 | 04:12 PM
Tommy_Gunns's Avatar
I can't stress this enough...SOLDER is your friend. Crimp connections no matter how tight will eventually come loose or oxidation will get in-between the wires and you'll have a bad contact.
-Tommy who had to re-wire his alarm cause the idiot who installed it just used the twist and tape method.
Old Jun 5, 2002 | 07:52 PM
shirubia's Avatar
Default Re: The R is runing like ***! (Tommy_Gunns)
USDMSiR
Aug 25, 2006 01:34 PM
crackerjacker006
Aug 4, 2005 01:48 PM
tegon-gsr
May 1, 2004 04:38 PM
M-EJ1
Apr 4, 2003 12:50 PM
Hybrid 350GT
Nov 8, 2002 02:14 PM
