Alarm recently installed, now my lights wont work, HELP!
Old Jun 18, 2007 | 05:07 AM
lduque's Avatar
Default Alarm recently installed, now my lights wont work, HELP!
Hey on saturday my alarm was installed, A prestige one, everything was fine untill night time. I remote started it, all was well when i suddenly saw my front lights didnt turn on. So i had to drive all the way home with my high beems on. Any Ideas on what could be wrong?
Old Jun 18, 2007 | 06:37 AM
fcm's Avatar
fcm
Old Fart
Default Re: Alarm recently installed, now my lights wont work, HELP! (lduque)
Did you check the fuses?
Who installed the alarm?
An alarm install should have nothing to do with the head lights. 94
Old Jun 18, 2007 | 07:55 AM
lduque's Avatar
Default Re: Alarm recently installed, now my lights wont work, HELP! (fcm)
The alarm was installed by a tech at the shop i bought the alarm at.
Im not sure which fuse I would have to check.
Can you help in tryna figure this out?... I know it has to do with the alarm cause it was working fine before.
Old Jun 18, 2007 | 09:37 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lduque &raquo;</TD></TR><TR><TD CLASS="quote">The alarm was installed by a tech at the shop i bought the alarm at.
Can you help in tryna figure this out?... I know it has to do with the alarm cause it was working fine before. </TD></TR></TABLE>
Then take it back to the shop at which you had the alarm installed.
Old Jun 18, 2007 | 04:37 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
Then take it back to the shop at which you had the alarm installed.</TD></TR></TABLE> Ditto that, don't mess with the alarm install, it may void your warranty on the install and the alarm itself, most shops will have a lifetime warranty on install, as long as it's not messed with.
You can check the fuses, there will be 2 of them in the under dash fuse box, need MM&Y of car and I may be able to tell you which fuses, but it will also be in the fuse box cover. 94
Old Jun 19, 2007 | 05:41 AM
lduque's Avatar
Thanks for all the advice. I figured it would be best to go to the tech dude.
I will come back with more questions after Saturday if it turns out the alarm wasnt the problem..
thanks again
1BADEGDC2
Audio / Security / Video
Dec 30, 2008 04:29 PM
ctownintegra
Mar 10, 2008 08:24 AM
JasonST
Apr 28, 2007 04:07 PM
mehdiR
Aug 29, 2005 07:43 AM
XtremeGirlRacer
Apr 11, 2003 04:57 AM
