replacing main bearings, any suggestions while i'm down there?
Old Jun 18, 2007 | 04:42 AM
xxmastermindxx's Avatar
Default replacing main bearings, any suggestions while i'm down there?
I'll be replacing my main bearings soon, and am wondering what you guys think I should do while the motor is out.
Definitely all main bearings (spun #3)
Clutch
Timing belt
Front and rear main seals
Rod bearings?
Any head/block work?
I guess I can do rod bearings too, just to add a little security. They do look fine though. I don't know if I will be keeping the car or not, most likely will. Probably going to keep it mostly stock NA. Working with about a $500 budget here, so let me know what you guys think.
Thanks
Old Jun 30, 2007 | 08:53 AM
Default Re: replacing main bearings, any suggestions while i'm down there? (xxmastermindxx)
Old Jun 30, 2007 | 09:02 AM
Missing Gears's Avatar
if you spun a main, i would have the crank and block checked out professionaly.
Old Jun 30, 2007 | 09:23 AM
SikB's Avatar
Default Re: replacing main bearings, any suggestions while i'm down there? (Missing Gears)
take out the balencer shafts and switch to a manual tensioner if applicable. Replace water pump if needed.
Old Jun 30, 2007 | 11:34 AM
lude98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Missing Gears &raquo;</TD></TR><TR><TD CLASS="quote">if you spun a main, i would have the crank and block checked out professionaly.</TD></TR></TABLE>
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SikB &raquo;</TD></TR><TR><TD CLASS="quote">take out the balencer shafts and switch to a manual tensioner if applicable. Replace water pump if needed.</TD></TR></TABLE>
Old Jun 30, 2007 | 03:34 PM
Default Re: replacing main bearings, any suggestions while i'm down there? (lude98SH)
i'm having the crank checked definitely, it looks fine but i'm having it polished/balanced.
why the block? the spun bearing has mild damage, i mean it's spun, but not shredded to pieces where i have to worry about chunks of metal in the motor.
i am however flushing my oil system of course.
Old Jun 30, 2007 | 04:41 PM
because if the bearing spun, it will usually eat some aluminum from the block. you will have to check the line bore.
Old Jun 30, 2007 | 06:34 PM
ok, i think i get you.
line bore would be i'm guessing the "trueness" of where the crank sits?
I_eat_Rice
Jul 6, 2008 12:58 AM
mymeatb18"
Sep 4, 2007 09:40 AM
pumpkyn
Oct 6, 2006 02:26 PM
JaHnAbOi
12
Jun 22, 2006 11:00 PM
luckypon7
Nov 21, 2003 05:13 PM
