new motor... need opinions
first and formost i wanna say... im not goin B or K series. im sticking with the D series non v-tec. i have a D15B8 8 valve motor that the bottom end is straight on. original miles isnt even 90,000. i have a D16A6 head that is being refreashed now as we speak. im gonna with D16A1/ ZC pistons. but my question is what rods and crank should i or could i use? im worried that if i go with the A6 rods and B8 crank ill smack the head. any healp would be greatly appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">This might be best in the all motor forum. </TD></TR></TABLE>
It must suck having to babysit all day.
i have all the parts i need from previous motors that are in good condition. ZC pistons are the same bore... 75 mm. i guess the only way ill find out is to mate the head to the block with SI rods and find out.
ok next question then is which intake? i have an A6, a Z6, a Y8, and an OBX. also throttle body's. ive used a newer throttle body on my A6 once before. couldnt feel a difference but would a newer one be better. all i did was take off the map sensor and block it off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obd1_crx »</TD></TR><TR><TD CLASS="quote">ok next question then is which intake? i have an A6, a Z6, a Y8, and an OBX. also throttle body's. ive used a newer throttle body on my A6 once before. couldnt feel a difference but would a newer one be better. all i did was take off the map sensor and block it off.</TD></TR></TABLE>
I would suggest the Y8 manifold with a B-series throttlebody.
The other manifolds you list would work just fine too, just stay away from the OBX manifold. I've seen it lose power on the dyno...on a turbocharged D16Y7.
