Question about a wire
So well doing some wiring on my CRX (91 SI). Was a little hack from the owner. Some wires were cut and replace with a 2 inch new piece of wire. Most have had something to do with something they did in the past. So i come across this wire that was cut and have no clue were it goes. After searching a little, solid green on the white plug. Came up as the A6 wire which is the purge cut off solenoid valve. I have a mini me swap in the car (d15b2 block/d16z6 head). Going obd1 via a Rywire conversion. I read a little bit of it having something to do with the canister. There is some hoses that have been already plugged up. Guessing it has to do with there previous cutting of the wire. Im also sure i will remove the canister as it is not needed.
So the question after my story. Yes i like to type.
Do i need this or can i just tape the end up after the plug?
hotimportcrx
Feb 6, 2006 11:45 AM
daklown
Jun 9, 2004 10:12 PM
