Upper Radiator Pipes (Good / Bad) Stainless or Aluminum?
Old Jun 17, 2007 | 06:04 PM
TurboSI56's Avatar
Default Upper Radiator Pipes (Good / Bad) Stainless or Aluminum?
What are your guys opinion on stainless or aluminum upper radiator pipes, on every car I ever own I always end up making it out of stainless and adding a bung for water temp so i dont have to drill and tap a factory line.
Which material do you prefer to use, and which do you think would be the most logical to use. I prefer Stainless for it's strength, and versatility, however alot of people seem to prefer aluminum.
Oh and for fun check out this twin turbo kit i made for the 350z Twin GT37Rs, twin tial 44mm wastegates, 5.1'' thick garrett core yada yada
Old Jun 17, 2007 | 06:31 PM
mmonday's Avatar
sorry i have no answers, i just wanted to say wow...twin 37r should make some power!
Old Jun 17, 2007 | 06:57 PM
TurboSI56's Avatar
Default Re: (mmonday)
hopefully, its a 4.3l stroker, 3.5'' downpipes 5'' single exit exhaust, standalone, 1600cc injectors etc. w/ 150 direct port, granted its not a race car and all of the numbers it does produce will only be used for show purposes
Old Jun 17, 2007 | 07:32 PM
ssmdc2's Avatar
Default Re: (TurboSI56)
Very impressive work on the 350Z. I'm sure getting all that to fit is no easy task. As for the coolant pipe, I would use aluminum. I think aluminum is so much easier to work with (cutting, grinding, etc) and it's heat properties are better. Either one would probably work equally as good, but I would prefer aluminum. Just my .02
Old Jun 17, 2007 | 08:48 PM
arc_55's Avatar
Aluminum would disapate heat better then the stainless steel and as ssmdc2 said it would be must easier to work with.
Old Jun 18, 2007 | 05:21 AM
91jdmhatchback's Avatar
Default Re: (arc_55)
i would use aluminum also...
Old Jun 18, 2007 | 06:02 AM
Fred Allen Burge's Avatar
Default Re: (91jdmhatchback)
I'd love to see some more pics of the Z manifolds. Do you have any out of the car?
turbosforsale@hotmail.com
Thanks,
Fred
Old Jun 18, 2007 | 06:58 AM
R@mon's Avatar
Did you get a standalone that would control the VCT system? I've been looking for something good that can do it but haven't had any luck. I have one in a 240sx.
Old Jun 18, 2007 | 03:48 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: (R@mon)
To the OP: Id use Al for the reasons that were previously stated. The fab work looks great on the Z
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R@mon &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
******* sweet. Anymore pics of it?
It looks like you might run into some hood clearance issues
Old Jun 18, 2007 | 05:33 PM
tepid1's Avatar
Default Re: Upper Radiator Pipes (Good / Bad) Stainless or Aluminum? (TurboSI56)
I say AL w/ Wiggins.
Old Jun 18, 2007 | 05:34 PM
JDMCRX's Avatar
Default Re: (sCeRaXn)
Thing is going to be a rocket
Old Jun 18, 2007 | 06:57 PM
R@mon's Avatar
I don't want to thread jack. I'll start my own thread with more pictures.
philcivicjordan
Nov 4, 2015 05:50 PM
egizzle8
Nov 24, 2003 04:32 AM
Diego Boost
Mar 3, 2003 03:02 PM
Denny317
Apr 14, 2002 05:25 PM
d mafia
Dec 7, 2001 08:23 PM
