Does this head looks okay?
Old Jun 17, 2007 | 08:48 AM
Mark27's Avatar
Default Does this head looks okay?
I've been working on a 98 LS with a few bent valves, then I came across this head for a low price.
Does it look okay?
Old Jun 17, 2007 | 08:50 AM
deadline's Avatar
looks normal to me..
Old Jun 17, 2007 | 09:06 AM
o0oz's Avatar
Default Re: (deadline)
cant really tell just by looking at it. you need to check it for cracks and warp.
Old Jun 17, 2007 | 09:28 AM
super jdm yo's Avatar
Default Re: (o0oz)
set one of those square thingy against the bottom of it to see if there any warping
Old Jun 17, 2007 | 10:36 AM
djtsmith007's Avatar
Default Re: Does this head looks okay? (Mark27)
Pmed
Old Jun 17, 2007 | 10:44 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
someone didn't like to change their oil. there's a layer of coked oil on everything. i'd try to find a better one.
Modified by full Circling at 4:30 PM 6/17/2007
Old Jun 17, 2007 | 12:01 PM
Reza^'s Avatar
Default Re: (full Circling)
take it to a machine shop and have them look it over and make sure its not warped, it's worth the small fee .
Old Jun 17, 2007 | 01:22 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (.:Reza:.)
heres one i bought to compare. Bought off ebay for 50 bucks.
Also a 98 Ls head
Old Jun 17, 2007 | 01:25 PM
1.8L_allmotormilitia's Avatar
might need to deck the head before you put it on. but looks ok.
Old Jun 17, 2007 | 06:03 PM
98GSRDC2's Avatar
Default Re: (1.8L_allmotormilitia)
check the internals of it for cracks. also check under that slab of old oil for anything bents
Old Jun 18, 2007 | 03:10 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
looks like someone never changed their oil and looks like a high mileage head could be wrong?
Old Jun 18, 2007 | 04:28 PM
projectTeG's Avatar
looks not taken care off, try another one or repair your head with new valve,spring,seals, and a valve job and it will be like or better than new again.
Old Jun 18, 2007 | 04:34 PM
redDAinteg's Avatar
Default Re: (projectTeG)
Whenever I took the valvecover off of my old LS, it looked ALOT cleaner than those heads. But now its p72 > p75.
Old Jun 18, 2007 | 05:35 PM
myfirstdc2's Avatar
it looks ok. it's fine. From the looks of it, possibly high milage/or not well taken care of head. i would still change out the stem seals and get the head resurfaced. it should be done before u put it on anyway. so its's all good . i have a ls head in the garage that looks just like it. 256k miles on it so i wouldn't be surprised to see it like that. and i also just redid seals and resurface another head. this is want u want :
there you go. hope this helps
Modified by myfirstdc2 at 10:44 PM 6/18/2007
Old Jun 18, 2007 | 06:05 PM
Sam92Teg's Avatar
Default Re: Does this head looks okay? (myfirstdc2)
I have 304K miles on my RS, and the head looks much cleaner than the one you are looking at. Castrol GTX every 4-5K miles FTW! I agree with taking either your stock head or that head to the machine shop and let them clean, pressure test, check for warpage, and replace the valve seals. You will be suprized at how cheap they will do all that for.
Old Jun 20, 2007 | 11:18 AM
Mark27's Avatar
Thanks for the Pms and replies. Now I have an idea of what to do
Old Jun 20, 2007 | 11:30 AM
DeltaCharlie2's Avatar
Default Re: (Mark27)
It looks okay, but it's hard to judge the condition of a head through pix alone. Did it come off of a running car? I would take it to a machine shop and have them check it out.
Spawne32
May 21, 2010 06:29 PM
B16aDasher
32
Mar 29, 2005 05:27 AM
deeksmooth
Jun 26, 2004 11:51 PM
Wazup
Dec 9, 2003 03:32 AM
ghettoracer
26
Sep 22, 2002 03:54 PM
