New Radiator problem for crx!!!!!!!
Old Jun 17, 2007 | 07:55 AM
tinoeast14k's Avatar
Default New Radiator problem for crx!!!!!!!
I have a 90 crx, I put a new radiator in and nothings working!!!!!! There is no anti-freezy going to the motor, im not sure of the problem!!!!!! Can anyone help??????
Old Jun 17, 2007 | 04:57 PM
QuickStyle's Avatar
you need to fill it up with coolant first, and it may take a minute or two to circulate before you see the coolant moving. why dont you describe your problem in more detail so people can understand.
Old Jun 17, 2007 | 05:04 PM
RockinthEFhatch's Avatar
Default Re: New Radiator problem for crx!!!!!!! (tinoeast14k)
Did you connect it to anything? Or just set it in there...
Try filling the radiator with 60% distilled water and 40% anti-freeze or around. Make sure the drainplug is locked on the bottom of the radiator and make sure there is a hose connected on the bottom of the radiator and the top. Hopefully after that the "anti-freezy" (******) will flow through your motor.
Old Jun 18, 2007 | 12:45 PM
I put the new radiator in, connected all the wires correctly and the hoses!!!! But there is no coolant passing threw the hoses!!!!!
Old Jun 18, 2007 | 05:21 PM
QuickStyle's Avatar
add coolant then
civicsir94
May 20, 2008 03:21 AM
tinoeast14k
Jun 18, 2007 12:56 PM
94gsr_vtc
12
Jul 26, 2004 08:23 AM
jkn1515
Jul 2, 2003 03:33 PM
Chip398193
Sep 10, 2001 01:12 PM
