check timing on a d series?
Old Jun 16, 2007 | 08:06 PM
hondacivic90zc's Avatar
Default how to check timing on a d series?
i am just curious how to check the degrees of timing on a sohc zc with a timing light because i dont see where you could or can you at all? I know it may be a stupid question but i need to know so i figured i would throw it out there.
Another question is which direction of rotation of the dizzy advances and retards the timing?
Old Jun 16, 2007 | 09:09 PM
Default Re: how to check timing on a d series? (iandavis90)
nobody knows?
Old Jun 17, 2007 | 09:21 AM
cant somebody just give me a simple yes and how to do it or no it cant be done?
Old Jun 17, 2007 | 10:04 AM
cornfed85's Avatar
to check the timing theres 3 little notches on your crank pulley closest to the timing belt cover and theres a little pointer that sticks off the belt cover you want that pointer right around the center of the 3 lines....and for the dsitributor im pretty sure forward advances and backwards retards dont quote me on that i didnt have to mess with my distributor when i replaced my head and timing belt i didnt see that you said zc...as long as its sohc it should be the same as any other single cam honda motor
Old Jun 17, 2007 | 10:11 AM
cornfed85's Avatar
if your motor is the same there will a set of notches that look like this ||| | the set of 3 when you put a light on it you want the pointer on the belt cover to be almost if not dead on with the center one the 1 notch by its self is the one you need then your setting the #1 piston to tdc by hand thats how i was told and and i never timed a honda and i got it pt together and it fired right up
Old Jun 17, 2007 | 12:56 PM
Default Re: (cornfed85)
thanks i will take a look
mxjosh
Dec 10, 2008 07:03 PM
getdowndoyou
Mar 14, 2007 08:14 PM
NatedoggAZ
14
Apr 13, 2005 09:51 AM
22boost
Oct 13, 2004 06:40 PM
wpgcivic
Jun 17, 2004 06:18 AM
