startup oil pressure for fresh motor
Old Jun 16, 2007 | 04:06 PM
B18EG6's Avatar
Default startup oil pressure for fresh motor
edit-please scroll down
Hey-
I am finishing a build and its time to start the motor... I have never had an oil pressure gauge so I am not familiar with the pressures on startup/idle
I cranked the motor over for 10s or so and noticed the pressure increase to ~30psi but then drop as soon as I stopped cranking.
What should I look for/avoid when starting a fresh motor with regards to the oil pressure? Any advice or tips would be greatly appreciated
Thanks!!
Seb
Modified by B18EG6 at 5:45 PM 7/5/2007
Old Jun 16, 2007 | 04:52 PM
shortyz21's Avatar
Default Re: startup oil pressure for fresh motor (B18EG6)
if u got 30 cranking your good to go.
60-80 when cold... fire that sucker up
Old Jun 16, 2007 | 04:53 PM
numbnuts22715's Avatar
yep, thats all i got.
then after starting it, it shot up to like 72 or something like that, I dont really remember, it was realllly late in the middle of the night.
Old Jun 17, 2007 | 12:13 PM
B18EG6's Avatar
Default Re: (numbnuts22715)
Awesome, thanks for the advice.
On another, related note.... I have 3 year old gas in the tank
I checked for rust by peeking in, I take it I should probably drain it all and replace it with fresh gas?
Old Jun 17, 2007 | 12:16 PM
I would definitely replace it...
Dont want thatgas ffucking up an injector, or anything like that.
Old Jun 17, 2007 | 04:32 PM
tepid1's Avatar
Default Re: (B18EG6)
I just fired up my fresh motor last week or so and again today. I got mid to low 70's once started. Sounds good to me.
Old Jun 17, 2007 | 05:25 PM
alpha's Avatar
Drain that gas and refill with new gas before you run the motor
Old Jun 17, 2007 | 05:30 PM
B18EG6's Avatar
Default Re: startup oil pressure for fresh motor (alpha)
Is the drain bolt on the tank sufficient for getting all of the old gas out, or would I need to siphon it somehow?
Old Jun 17, 2007 | 09:14 PM
Tippyman's Avatar
Drain it with the bolt, and throw a gallon or two of fresh gas in there, then drain it again. Then fill it.
May seem wasteful, but it'll get out the old **** and dilute whatever's left so it won't matter.
Old Jun 18, 2007 | 03:33 AM
B18EG6's Avatar
Default Re: startup oil pressure for fresh motor (Tippyman)
Eh, wasteful or not I would rather be safe
Thanks a lot for the advice... if you know of any other tips for the first start up, I would love to hear them. This is only the second fresh motor I have started, with the first not even being my own car
Thanks!!!
Seb
Old Jul 5, 2007 | 01:45 PM
B18EG6's Avatar
finally started the motor!
The oil pressure was ~50 at idle - is this indicative of a leak somewhere? Don't know if this factors into things, but I have two -12AN coming off the VC and two more -12AN coming off the back of the block to a catch can.
black2001ITR
Feb 4, 2005 05:11 PM
Ecugrad
Jan 15, 2005 01:28 PM
hondaeg8
Feb 3, 2004 01:05 PM
hondaeg8
Jan 26, 2004 03:37 PM
quik1
Aug 3, 2003 12:50 PM
