engine will not run
I'm working on a 91 honda civic wagon. The engine will not try and take off when I spry staring fluid in Air Intake. What would becausing this, and what do I need to to.
Any help will be aprreciated. Thanks
Check for fuel- when you turn the key on, do you hear the fuel pump prime? Crack the fuel line at the filter. Does it have pressure(it should spray out)
Check for spark- pull a plug wire, pull a plug. Stick the plug in the end of the wire and ground it. Crank the car over. Is it sparking?
These are your best starting points(assuming it has gas in it).
I have to get another fuel pump from junkyard, because it won't run, I do have spark. tried sprying starting fluid through rail, and it still won't try to start. When I check the spark plug there is oil around the nut part. Do u think that the engine is bad. Thank you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke »</TD></TR><TR><TD CLASS="quote">Check for fuel- when you turn the key on, do you hear the fuel pump prime? Crack the fuel line at the filter. Does it have pressure(it should spray out)
These are your best starting points(assuming it has gas in it).</TD></TR></TABLE>
Ditto!!
Ditto!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david542 »</TD></TR><TR><TD CLASS="quote">there is gas in the tank, it is full, when the line off at filter there is no sprying, blew through both lines and they not blocked.</TD></TR></TABLE>
If there is no pressure, then your pump is not working. Maybe you have an electrical issue.
no power going to fuel pump relay, and to fuel pump, however when the igintion is turn on i hear a click for about 3 sconds. do u think that my ecu is bad. Thank you
I'm going to the junk yard this weekend, and I would like to know all that I need to get for this car. I would like some ideas on this. Thank you
I got another fuel pump, wired it to the battery and it started, however I still don't have power at the plug for the pump. The pump rely clicks, when I put a test light to it, it lights up. I wish somone would tell me excatly where the prolem lies. I been working on it for awhile.
I do have power at the fuel sending unit, so i'm going to check for a short. do u or anyone know how the wire is routed. it would be greatly apprecited. Thank you
mmmm no.. im not sure how its routed but... it should go back along the drivers side till you get to the seat and then i think it just goes straight over to the pump... i think hope this helps
far as i can tell the wire runs under the body, but not sure where it comes up through the floor and hookes into to the ones that run along it from pass side to drivers side.
DansaHondaMan
Aug 26, 2013 10:28 AM
trecool44
Jan 11, 2008 10:46 AM
econobox
Oct 21, 2004 05:25 PM
