RUNNING really rich after hard launch
ran my car at the track last night, and i got CRAZY wheel hop.... It knocked my header off of my resonator (on w/ clamps
) and i was running open header down the rest of the track. Now the idle is really sketchy (REALLY LOW 500) and the car is running really rich. Plugs r black, smells like gasoline, wasted 1/4 tank on 20 miles... its running like absolute ****
Im running p28 w/ a basemap if that matters
my setup: jdm h22a, no balance shafts, i/h/e/clutch/flywhee/ zex 75 shot dry
) and i was running open header down the rest of the track. Now the idle is really sketchy (REALLY LOW 500) and the car is running really rich. Plugs r black, smells like gasoline, wasted 1/4 tank on 20 miles... its running like absolute ****Im running p28 w/ a basemap if that matters
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvteclude »</TD></TR><TR><TD CLASS="quote">did it tear the o2 sensor wires?</TD></TR></TABLE>
Yeah, it probably f'ed up the O2 sensor....
if the o2 is fubar'd might as well get an o2 simulator for a replacement.
never gotta worry about an o2 sensor again after buying a simulator.
welli havent started it up yet but here is the damage thus far:
-Sheared vtec solenoid plug (Coil came loose and smashed it)
-Map sensor vacuum disconnected (HOPEFULLY PROBLEM)
-Fouled Spark plugs
-Loosened my radiator DRAIN!?!?! it was leaking coolant i thought the motor was toast...
-Fouled Spark plugs
what are you doing to compensate for that 75 dry shot your running?? u should consider using a wet shot.
maybe your ecu is overcompensating cause its recognizing the nitrous, so its injecting extra fuel?
p.s. what was your time??
p.s.s. I dont know why people get so much wheel hop. are you just dumping the clutch off the line? i normally get NO wheel hop what-so-ever.
u need to stage that nitrous or put in an rpm activated solenoid,that's WAAAAY too many traction issues at launch man.
and bolt your header up properly next time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkBB4 »</TD></TR><TR><TD CLASS="quote">welli havent started it up yet but here is the damage thus far:
-Fouled Spark plugs
i;m surprised you managed to mess up all that from wheel hop, when there's a really quick fix to wheel hop which you can engage during the launch. let off the gas
-Fouled Spark plugs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">get your car fixed and tune your car. wtf are thinking running a 75 dry shot on a basemap
fixed
</TD></TR></TABLE> fixed
ok first of all, i did not spray nitrous that run.
-i have a msd window switch,i just gotta get a relay and finish wiring it in...
-i retarded the timing, and i'm running bkr7es plugs.
-I usually never have wheel hop, but the NRG engine damper fucked mad **** up... I ran a 2.1 60 foot that run.
the wheel hop is from good grip cold tires, spinning way to fast to get a good hold. Stop jaming the gas off the line and maybe you can clean up your take off and lower your 1/4 mile and 60' times.
the object in draging is to not spin your tires off the launch.
you wanna do a burn out go in a parking lot.
but save the racing for the track, where peeling out isn't the impressive goal to be obtained!
ATS*Mark
Apr 7, 2004 07:06 AM
spencedogg
27
Nov 20, 2003 04:20 PM
