cheapo b18a cam choices??
Old Jun 16, 2007 | 07:30 AM
pauld's Avatar
Default cheapo b18a cam choices??
Interesting thought...I'm being a total cheapass by even suggesting/asking this. I have a b18a swapped in my crx. Has anyone run the b18b cams or even the cams from a b20crv in the b18a. Is it worth my time??? any real gains??? The cam specs list longer duration, greater lift, etc. for both the crv/b18b cams, and they are pretty much a give-away used. Thing is that an aftermarket cam and spring/retainer upgrade is worth more than my whole motor, and like I said , I'm a cheapass.
Anyone gone there? results?
Old Jun 16, 2007 | 08:41 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
a b18b intake cam will make your car run a bit smoother, and i'm sure a b20z cam would do the same thing. the later b20z intake cams have a LITTLE more duration than the LS's, so if you have the option, grab one of these ones.
i put a jdm b18b intake cam in my '91 ls, and i noticed a difference in idle quality, and just overall smoothness in the engine. not too much at all in the power department, though.
Old Jun 22, 2007 | 12:56 PM
DB1_559's Avatar
Default Re: cheapo b18a cam choices?? (pauld)
i had the 95 ls cam in my b18a notice quite a differnt but that was with the im/tb too
honda-dummy1
Apr 12, 2013 09:06 AM
91da9ls
Jan 31, 2007 10:38 AM
Snail Tuning
May 5, 2005 09:01 PM
syndicate43
May 24, 2004 07:56 AM
89-ef
Feb 18, 2004 02:33 PM
