rear disc swap
Old Jun 16, 2007 | 05:46 AM
jonnydbagz's Avatar
Default rear disc swap
del sol or integra? are the integra rotors bigger? which would you rather have?
Old Jun 16, 2007 | 06:48 AM
99 Civic EX's Avatar
Default Re: rear disc swap (jonnydbagz)
either one will work, and my guess is that maybe the integra rear discs might be a little bit bigger, but again, i'm just guessing on that one.
Old Jun 16, 2007 | 08:34 AM
instrument's Avatar
why don't you go check the part numbers?
i'd assume they were all the same.
Old Jun 16, 2007 | 08:56 AM
pdiggitydogg's Avatar
why are we still having threads like this?
theyre all the same...88-01 civic/integra
period.
just get cables that best fit your chassis
read this next time
https://honda-tech.com/zerothread/1998336
Old Jun 16, 2007 | 09:05 AM
jonnydbagz's Avatar
because there are still people that need info and cant find anything by searching. why do you read it if you dont want to contribute positively?
Old Jun 16, 2007 | 09:15 AM
I did contribute positively - i told you the answer.
Ive read that page...thats why i told you to read it
and if you cant find it by searching, youre not searching correctly
use the archives, try different words, use your eyes and read more than one line before giving up
Old Jun 16, 2007 | 09:22 AM
4drgsr96's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">I did contribute positively - i told you the answer.
use the archives, try different words, use your eyes and read more than one line before giving up</TD></TR></TABLE>
oooohhhhhh burn..........
Old Jun 16, 2007 | 09:23 AM
FalkenSiR's Avatar
Default Re: (4drgsr96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drgsr96 &raquo;</TD></TR><TR><TD CLASS="quote">
oooohhhhhh burn.......... </TD></TR></TABLE>
grow up
Old Jun 16, 2007 | 09:39 AM
jonnydbagz's Avatar
ive read the link, many times, just didnt catch if one came with bigger rotors. thank you
Old Jun 16, 2007 | 09:50 AM
bmoua's Avatar
i'm guessing the teg's calipers will be slightly bigger...not by much though. I know the 94-01 rear teg calipers are slightly bigger than the 99-00 Si's.
*correct me if i'm wrong...
Old Jun 16, 2007 | 09:54 AM
No...all rear disc setups are exactly the same
https://honda-tech.com/zerothread?id=1122596
(thats ONE thread on this)
If you want, go ahead and cross reference rotor and pad part numbers at http://www.buybrakes.com
You'll find that theyre all the same.
Old Jun 16, 2007 | 11:54 AM
jonnydbagz's Avatar
all clear now, thank you all
usdmdc2
Dec 28, 2008 01:28 AM
90_civic_Si
Suspension & Brakes
Feb 2, 2007 11:22 AM
joshb_
Jan 23, 2007 03:44 AM
unknown0001
14
Aug 11, 2005 05:31 AM
unknown0001
14
Aug 30, 2004 09:00 PM
