mini me swap has detonation
Old Jun 16, 2007 | 12:33 AM
michangelo's Avatar
Default mini me swap has detonation
i have a DX EG hatch with a d15b7 block an a d16z6 head...running thed 15b7 distributor and intake manifold...with b16 injectors.wen i cruz it "1/4 throttle" it runs "ok" wen i give it gas i hear detonation.....an not much power at all...anyone got any ideas?? p.s " stock ECU an the V-tec is not hooked up yet"
Old Jun 16, 2007 | 07:35 AM
2point2's Avatar
what have you tried so far?
Old Jun 16, 2007 | 12:11 PM
vtecspeed1320's Avatar
Shooting Star
are you meaning the p28 ecu...if so then you need to put some 93 oct gas in it, then you will have to get it tuned...we had spark knock in a friend of mines until we put in some 93 and then after that you can tune the car later for 89 or whatever fuel you want to run.
Old Jun 16, 2007 | 05:03 PM
michangelo's Avatar
i have the stock i.5 dx ecu...i think its the p06....i have 93 oct. still detonating..could this be a cam timeing...or mabe ignition...
Old Jun 16, 2007 | 05:32 PM
Shooting Star
you might need to pick up a p28 ecu, the best i remember it was the p06 ecu that was giving knock...its not enough fuel for the ignition timing in that motor.
Old Jun 16, 2007 | 05:57 PM
michangelo's Avatar
so changing the injectors wont help?...oh an would i have to notch the pistons?i herd that wen in vtec ill hit valves...
ecko22
Aug 8, 2012 06:52 AM
First.EG
18
Jan 24, 2012 08:23 PM
88HATCH(:
Sep 25, 2011 12:45 PM
HKchich
Sep 15, 2011 10:48 PM
ted
10
Feb 22, 2005 10:04 AM
