d16y7 to 93 eg swap issues.
im bout to swap out my tired d15b7 to my fresh d16y7. my question is , what ecu do i run? do i run the common chipped p28 ? thanks in advance
Technical Hero
Re: d16y7 to 93 eg swap issues.
Run the same ecu you are using now. Swap over distributors, alternator, intake (including injectors) and exhaust manifolds from your old motor to the new one. Basically the simplest swap you can do. Ignore the CKF sensor by the crank on the new motor you won't plug it in or use it.
will the d15 injectors and ecu be good enough ? im far from stock .. port n' polished head . FJD forged/h beam combo . so is it juss better if i find a chipped ecu now ?
streetcartuner
01-07-2007 12:11 PM
ted
03-22-2005 01:14 PM
