94 front fender lining question.
park your car in the sun and put like 15-20 pounds on the middle of each side of the hood and let it sit for a while for a few days. as the the fender lining, the front bumpers are different so the lining might be a little different also..it shouldnt be anything you cant fix without minor modification.
The fender liners are the same, so there shouldn't be a problem with them fitting. As for the hood, you'll have to check what's keeping it from closing. It could be the latch, the rubber bumpers, or some other spot, and each would require a different solution.
The fender liners are NOT the same.
My 94 bumper had tabs w/ holes that lined up with a speed nut on the fender liner for a screw to go through. My 2000 bumper has no such tabs. Ever since I did the conversion I've just held the front part of the fender lining in place with zip ties, as I've never got around to getting 98+ fender liners.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCL »</TD></TR><TR><TD CLASS="quote">why in the sun? i guess im goin to ha ve to change those fender liners cuz i have some layin around. thanks guys</TD></TR></TABLE>
Did you pick them up from somewhere? I need to get some because mine are torn up in a couple of places, but I don't want to pay $70+ each for new ones.
I bought one from a place in TN called Evans Honda Specialist back when I first got my car, because the right side one was missing, and it was only about $30 shipped. I'm not sure if they're still around, though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSracing94 »</TD></TR><TR><TD CLASS="quote">it will get hot and things strech better in the heat</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dc2.2 »</TD></TR><TR><TD CLASS="quote">My CF hood was a bit off when i got it. It aligned perfectly after leaving it a couple of days in the sun. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">
I bought one from a place in TN called Evans Honda Specialist back when I first got my car, because the right side one was missing, and it was only about $30 shipped. I'm not sure if they're still around, though.</TD></TR></TABLE>
thanks for the info. i mite pick up a set of password jdm hooddampers as well hope that helps. anyone using them? cuz i only have 3bolts bolted to the cf hood. one of the holes need to be redone...
the fender liners i got from another teg i have sitting on my drive way. roll over. its guna be sold soon so im guna take what i can
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">The fender liners are NOT the same.
My 94 bumper had tabs w/ holes that lined up with a speed nut on the fender liner for a screw to go through. My 2000 bumper has no such tabs. Ever since I did the conversion I've just held the front part of the fender lining in place with zip ties, as I've never got around to getting 98+ fender liners.</TD></TR></TABLE>
Good information. The part numbers are extremely similar, but the parts are indeed different. I stand corrected.
