Condensation in headlights help please
Old Jun 5, 2002 | 10:20 AM
integra15's Avatar
Default Condensation in headlights help please
OK. I have the 9005 conversion done in both headlights. I also have a repetitive problem of condensation in the right headlight assembly. Both the headlight and the bright have condensation in them. I dry them out by leaving the lights and brights on and the condensation seems to go away. But then I do some driving and it comes back.
So what is causing this? I dont think it is a bad seal, I cant see any light escaping from the back of the light when it is on. And the lights are vented anyways right? And why is it happening only on the right side?
Old Jun 5, 2002 | 02:47 PM
integra15's Avatar
Default Re: Condensation in headlights help please (Integra13)
Old Jun 5, 2002 | 03:33 PM
iH8RICERZ's Avatar
you have a crack somewhere on your headlights... I have the same problem w/ my passenger side tail light..theres a small crack somewhere letting in moisture.
Old Jun 5, 2002 | 03:37 PM
sutrusu's Avatar
it's probably the seal for the lights. replace it.
Old Jun 6, 2002 | 07:06 AM
integra15's Avatar
Default Re: Condensation in headlights help please (sutrusu)
I thought they dont come apart, but I could be wrong. Anybody ever taken them apart to clean them or replace a seal?
Old Jun 6, 2002 | 08:04 AM
redlinegsr's Avatar
make sure the healight clip is sealing the bulb into the housing
Old Jun 6, 2002 | 08:08 AM
reefer_bob's Avatar
Default Re: Condensation in headlights help please (redlinegsr)
Take out your bulbs (its easier if you take the whole headlight assembly out. Use a hair drier, and dry out your headlights. By leaving on your headlights, you will clear the lens, but the moisture won't escape. blow hot air in there...
Old Jun 6, 2002 | 09:41 AM
integra15's Avatar
Default Re: Condensation in headlights help please (reefer_bob)
Thanks I will try that tonight.
Old Jun 14, 2002 | 04:17 PM
AzN_Flava's Avatar
damn this post is so timely... (i know that was worded horribly)
i washed my car yesterday and it happened on my left side.. both lenses...
Old Jun 14, 2002 | 05:12 PM
boo96TEG's Avatar
Just taking out the bulbs isn't enough. Take out the bulb, then twist off the black rubber ring that goes around the part the bulb goes in to. This gets you into the housing where all the moisture is. Leave the ring off, put the bulb back, turn on the lights and let it dry.
Old Jun 14, 2002 | 06:04 PM
AzN_Flava's Avatar
Default Re: Condensation in headlights help please (boo96TEG)
after doing this would it perminately remove the condesation? or is this something i should expect to happen from now on
Old Jun 14, 2002 | 06:30 PM
integra15's Avatar
Default Re: Condensation in headlights help please (AzN_Flava)
My condensation went away, so yours should too. I left the bulbs out all night w/ a fan blowing on the back of the lights.
RuckRider2
Jan 18, 2015 09:03 PM
{Sigur-Ros}
Jun 8, 2008 08:19 PM
rasinhell
Feb 17, 2005 04:35 AM
92cxgsr
Feb 25, 2002 01:04 PM
