Drying out condensationin headlights and re-sealing?
My tail lights and headlights are extremely wet inside. I was just thinking about the quickest way to get them to dry up inside so I can re-seal it with some silicon or something like that.
Anyone done this before?
Re: Drying out condensationin headlights and re-sealing? (NerveAgent)
How do I go about sealing the tail light gaskets? And what the hell are they anyways? A part of the actual tail light or is it a rubber strip that lines the spot where the headlight goes?
Re: Drying out condensationin headlights and re-sealing? (The-Beast)
Tailights seem to be a little bit trickier to get apart, they're certainly not as easy as headlights.
For the tailights:
Take them off and make sure they are completely dry on the inside, then run a very small bead all the way around the tailight where the seam is (where the two pieces join together). Use your finger to flatten the bead out a little and smear it. That should seal it up if you do it right.
For the headlights:
Take them off, and you can either open them up and clean the old glue/sealer away, or just do them similar to the tailights.
These lights don't use a rubber gasket, most use some type of silicone or a very thin epoxy type glue to seal them.
Good luck.
For the tailights:
For the headlights:
Good luck.
