T25 vs. T3
Old Jun 5, 2002 | 10:13 AM
ion_four's Avatar
Default T25 vs. T3
I am putting together a custom set-up on a d16z6 and have a Greddy manifold that had a T3 flange welded on it. I want to use a t-25 turbo because I'm planning on low boost, 5-7 psi, and I want it to spool up quickly. Does anyone know a shop in portland that could make a flange or adapter for me. The manifold is cast-iron. Should I just use a T3 turbo instead? will there be significantly more lag?
Old Jun 5, 2002 | 10:22 AM
Sonny's Avatar
Default Re: T25 vs. T3 (ion_four)
If you use a Garrett T3 with a .48 a/r exhaust turbine, it won't be very laggy at all. Garrett T3's with .48 a/r exhaust turbine and 50 trim compressor wheels came in many Saabs and Volvos. It will spool quick and give some pretty good power overall.
Sonny
Old Jun 5, 2002 | 11:24 AM
T3EMSI's Avatar
Default Re: T25 vs. T3 (Sonny)
I have a Airreasearch T3 in imaculate shape for sale. $350 and I will pay the shipping. You can get a piece of steel slap for your flange at a metal shop or your local sears sometimes they have em.
This t3 spools at around 3500 rpms on a 1.5L DX motor. lettme know if your interested
B16civicsi@aol.com
Ricky
PS
The T25 will spool quicker and hold boost, but a t3 gives you more options
Old Oct 19, 2002 | 06:23 AM
1990hondaHF's Avatar
Default Re: T25 vs. T3 (T3EMSI)
PS
What kind of options?
Old Oct 19, 2002 | 07:01 AM
POLLO's Avatar
Default Re: T25 vs. T3 (1990hondaHF)
Quick questions for some of you. Will a T3 super 60 suport 325 hp within its efficiency range ?
Old Oct 19, 2002 | 09:45 AM
SiRkid's Avatar
Default Re: T25 vs. T3 (POLLO)
super 60..yeah most likely
Old Oct 19, 2002 | 09:46 AM
prophet's Avatar
by options...i think he means if you ever decide to go bigger. T3/t4 turbos have a pretty high resale value and seem to always be in demand.
Old Oct 19, 2002 | 11:31 AM
Full-Race Javier's Avatar
probably, but its at its upper limit. check out the comp maps
Old Oct 19, 2002 | 12:29 PM
Default Re: T25 vs. T3 (prophet)
Got it!
Old Oct 20, 2002 | 01:55 AM
GOLDBERG's Avatar
i got my turbo off an 89?saab 9000 ...is it a t3??its garrett thas all i know, thnx
MISFITofMAGIC
Jun 5, 2006 08:35 PM
tgreaves
Nov 29, 2005 11:19 AM
integracivic94
Oct 17, 2004 09:19 AM
carbonDelSol
May 2, 2004 09:09 AM
servion
Oct 1, 2002 11:56 AM
