TPS voltage
I seem to have a couple flat spots when under light acceleration , I suspect the TPS to not be reading smoothly
Its NOT there under WOT
to read the voltage on the tps is it just a ground on the meter and read voltage on the green / red I believe
is this voltage correct I'm going on memory here
IDLE - under .50 volts
WOT - 4.9 volts
and then smooth transition in between
anything else to do while checking ?
WOT - 4.9 volts
kholmes
Oct 12, 2004 06:59 PM
