b-series swap in a 95 cx hatch
Old Jun 15, 2007 | 04:17 PM
BoogiepopJDM's Avatar
Default b-series swap in a 95 cx hatch
i was doing some research on b swaps and came across some threads ppl saying you need to change out the cx hub because it is smaller than the dx lx ex si,
ok now i went to majestic honda to review some part numbers and the hubs from the dx matched cx, now unless someone has first hand experience from this i would like to know
thanks
john
Old Jun 17, 2007 | 09:28 PM
sauceja's Avatar
Default Re: b-series swap in a 95 cx hatch (BoogiepopJDM)
You should be fine. Otherwise time for a brake upgrade anyway. Just get GSR at all four corners and a 40/40 prop valve. Brake master cylinder from a 91 civic ex sedan and your set.
They should fit though.
Old Jun 19, 2007 | 10:40 AM
sleepencivic's Avatar
Default Re: b-series swap in a 95 cx hatch (sauceja)
i have had 5 cx hatch's and did swaps on them all...if you going b-series your fine not sure on h-series think you have to get custom axels to use prelude halfshaft
Old Jun 19, 2007 | 02:24 PM
sauceja's Avatar
Default Re: b-series swap in a 95 cx hatch (sleepencivic)
Just go H2B and no H22 axle problems.
93 hatchguy
14
Feb 24, 2012 04:24 PM
nicholasmak
Nov 8, 2008 07:53 PM
tncivic-dvsb
13
May 27, 2006 12:15 PM
95CXSLEEPER
20
Jul 6, 2004 11:33 PM
sohcvtec66
62
Apr 15, 2004 11:16 PM
