96 Civic safe to turbo?
Old Jun 15, 2007 | 02:45 PM
ZanderGTS's Avatar
Default 96 Civic safe to turbo?
Ok so ive got a 96 civic ex with and original d16y8 w/ 123,XXX miles on it the motors pretty clean and has been treated well... Do you think it is safe to turbo this? I dont have any cash to put into another motor or alot of repair bills what do ya think?
Old Jun 15, 2007 | 02:46 PM
Padawan's Avatar
Darth ModerVader
Default Re: 96 Civic safe to turbo? (ZanderGTS)
Yes, it should be fine as long as it's done properly.
Old Jun 15, 2007 | 03:16 PM
Turbo_y8's Avatar
Default Re: 96 Civic safe to turbo? (Padawan)
do a compression test and/or a leak down test.
thatll give you a real answer instead of us guessing and saying itll be fine...
Old Jun 15, 2007 | 03:18 PM
Rust_si's Avatar
you should be alright as long as you run only 6 or 7 psi. A d series motor isnt the best choise for a turbo. you could probably find a b18 non vtec for pretty cheap and build a cheap turbo kit and have a decent amount of power- or maybe an H23.
Old Jun 15, 2007 | 03:34 PM
big-cat's Avatar
Default Re: 96 Civic safe to turbo? (Turbo_y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_y8 &raquo;</TD></TR><TR><TD CLASS="quote">do a compression test and/or a leak down test.
thatll give you a real answer instead of us guessing and saying itll be fine...</TD></TR></TABLE>
listen to him, he is right you have no idea where that car has been every single day of its life. but if everything checks out alright then yea it is fine.
Old Jun 15, 2007 | 05:37 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: 96 Civic safe to turbo? (big-cat)
Compression test. Leakdown test.
Milage has nothing to do with it. There are guys on d-series.org with 220whp and 200k+ miles on their cars.
Old Jun 15, 2007 | 07:37 PM
civicsi940's Avatar
what he said, and same goes for turbod16.com
Old Jun 15, 2007 | 09:11 PM
Turbo_y8's Avatar
Default Re: 96 Civic safe to turbo? (Rust_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rust_si &raquo;</TD></TR><TR><TD CLASS="quote">you should be alright as long as you run only 6 or 7 psi. A d series motor isnt the best choise for a turbo. you could probably find a b18 non vtec for pretty cheap and build a cheap turbo kit and have a decent amount of power- or maybe an H23.</TD></TR></TABLE>
so many lies/ doesnt know what he is talking about
jeff evans stock z6(d16) sees boost spikes which yeilds number 400+whp completely stock motor. i d series is fine for turbo charging, i pieced my kit together for $1800 and @ 11psi im making 252/215, find me a swap for that price that will make those numbers?
and an h23, horrible choice for boost, since they have fiberglass reinforced sleeves.
dont just write what you've heard
Old Jun 16, 2007 | 04:18 AM
big-cat's Avatar
dont just write what you've heard</TD></TR></TABLE> hey are you running arp's with that? and who tuned your car?
Old Jun 16, 2007 | 06:26 AM
Turbo_y8's Avatar
yes arp's torqued to 70 ft lbs, kms block guard, and cometic hp head gasket, street tuned by a local and had dyno tuned at speed quest performance in Il
Old Jun 16, 2007 | 07:04 AM
PistolStarta's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZanderGTS &raquo;</TD></TR><TR><TD CLASS="quote">Ok so ive got a 96 civic ex with and original d16y8 w/ 123,XXX miles on it the motors pretty clean and has been treated well... Do you think it is safe to turbo this? I dont have any cash to put into another motor or alot of repair bills what do ya think?</TD></TR></TABLE>
if you've got the time change the gaskets and seals, and yea ARPs
sh0rt1e67
Apr 2, 2009 10:00 PM
accord96vti
Jun 6, 2006 07:24 PM
dosterschill22
Oct 22, 2004 05:20 PM
Philbert
Feb 1, 2002 02:13 PM
JV
Jan 26, 2002 06:06 PM
