Clutch Engagement/Dilemma
Old Jun 14, 2007 | 09:26 PM
icemanxlb's Avatar
Default Clutch Engagement/Dilemma
Ok guys I already researched a lot of the threads about engagement points and etc.
I have a 2000 GSR with 75k miles and the clutch doesn't slip, etc. and still runs strong. But it engages at about 3/4 the way up!! Is that how it's supposed to be because I heard other people's tegs engage like near the bottom. I want my engagement point (catch point) near the bottom.
My clutch doesn't slip at all and is still very strong as I mentioned.
My pedals is 6.5" above the floorboard and the freeplay is about 0.5" which is right.
A mechanic told me since the engagement point is near the top, my clutch is worn, but I was like wtf, everything else is perfect!! What should I do?? Help thanks!!
Old Jun 14, 2007 | 09:31 PM
posHonda's Avatar
you can adjust the where the clutch engages...
Old Jun 14, 2007 | 09:34 PM
numbnuts22715's Avatar
It could be worn, but stll not slip.
Also, I thought yiou could only adjust whereit engages on cable trannies, not hydraulic trannys?
If I'm wrong, I apologize, but I've been told before that I cant adjust it since its hydraulic.
Old Jun 14, 2007 | 09:37 PM
icemanxlb's Avatar
Default Re: (iVteC_PoWeR)
No you can't, integras have hydraulic systems that adjust to wear. You can't adjust it
icemanxlb's Avatar
Default Re: (numbnuts22715)
So a clutch can still be worn, but not slip right??
Old Jun 14, 2007 | 09:40 PM
yes. It may be worn, just not enough to slip.
The closer the engagement point gets to the top = its more worn.
Eventually it will come to a point where it will slip and stuff like that.
Haarstad
Jun 24, 2012 09:50 PM
tigueremalo
Jan 14, 2007 02:29 PM
trianglegreg
Sep 29, 2005 09:50 AM
djsire
Sep 7, 2005 04:14 PM
DroppedTegLS
Sep 28, 2002 01:51 PM
