JDM B16 with J1 tranny VSS question-which electronic vss fits??
I have a JDM b16a with a J1 tranny in a 91 crx. I am going to swap my cluster which requires an electronic speed sensor. The speed sensor thats in there now is cable because it was used in a crx before i bought that motor. My question is what cars in the US use a VSS that will fit the JDM J1 tranny. Will the 99-00 civic si VSS fit in the b16 J1 tranny? What other model honda's should i get it from and what year?? Must be electronic VSS for new cluster swap!!!!!!!!
yeah you can use the 00 si vss..it works
but you dont have to limit yourself to that since theres zero at the junkyard...94 integra will work to and theres usually a bunch at yards..
92-95 civic may even work,however im not sure about those
look at this http://faq.ef-honda.com/index....ng=en
The one from a 94-01 integra 5 speed VSS will bolt in???
Someone offered me a VSS from a 95 civic si hatch....does this bolt in? Not sure if its from a d series vtec...but if it is will it bolt into a b series tranny??
B18 CYA
Apr 25, 2006 10:36 AM
HatchBox
12
Nov 24, 2003 03:11 AM
PhatHardy
Jan 31, 2003 04:55 AM
