INTAKE VALVES
hello all i was wandering and i was told that if i was to turn the intake cam i notch on the gear on the timing belt it would give me more peformance is this true ?? i got a 91 acura integra 1.8 dohc ? thanks and is this true on all dohc moters thanks again TONY
Modified by DUNKLEYMOTERSPORTS90T at 10:16 PM 6/14/2007
when linning up the timing marks on the cam gears anvance the intake cam gear i notch then put the belt on ? that what i got told to do.will the increce the performance?? thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DUNKLEYMOTERSPORTS90T »</TD></TR><TR><TD CLASS="quote">when linning up the timing marks on the cam gears anvance the intake cam gear i notch then put the belt on ? that what i got told to do.will the increce the performance?? thanks </TD></TR></TABLE>
I thought I just told you?
Do you have adjustable cam gears?
Do you even know what advancing the cam timing does?
Do you have a dyno to test how much power you are gaining or losing?
Do you have an EGT gauge to show you how the changes you are making are affecting your car?
