Help Please! Car Misfires
Old Jun 14, 2007 | 04:13 PM
DC4IntegraLS's Avatar
Default Help Please! Car Misfires
A couple of weeks ago, my Integra LS started misfiring once in a while. Sometimes when I'm accelerating in second gear between 2000 and 3500 rpms, it will misfire. The car feels like it has no power for a second, and the tach will drop 100 rpms and then go back up again. This happens in first and third gear too, but mostly in second gear.
It isn't misfiring all the time though, maybe 5-10 times every time I drive the car. If it's a hot day, and the car is warmed up, then it stops misfiring. My brother thinks it's the spark plugs, or the distributor, he says distributors go bad on Honda's often. My car has 86,000 miles on it, and I want to replace the timing belt soon, because I don't think it has ever been replaced.
If I was pretty sure that was the problem, I would have the Honda dealership replace the spark plugs when I got the car serviced. Has anybody had this same problem with their car, and if so, what fixed the problem? Any help will be greatly appreciated. Thanks
Old Jun 14, 2007 | 06:21 PM
DurtyVdub's Avatar
check your cap, rotor, see if its wet inside, also check your plugs,wires and coil
Old Jun 14, 2007 | 06:31 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Help Please! Car Misfires (DC4IntegraLS)
Pull the check engine light codes (see FAQ thread in forum). Your car is ODB2 and will tell you which cylinders are misfiring.
miguey310
Jun 2, 2009 12:29 AM
Mr.Death
Jul 29, 2006 02:52 PM
CleanLikeJdm
May 23, 2005 08:03 AM
wrXtian
Nov 14, 2003 10:02 PM
crxpowr91
Aug 11, 2003 06:20 AM
