please help no spark
Old Jun 14, 2007 | 01:36 PM
93formula's Avatar
Default please help no spark
info on the car:
ef hatch was d15b2, just swapped in a jdm d15b vtec to be run on obd0.
dpfi to mpfi.
originally used a pm6 and the car ran fine.
turned the car off to install what i was told was a jdm zc ecu. the car would no longer start, checked for spark, no spark.
car has brand new dist.
did all continuity checks on the ignitor leads and the secondary coil leads.
throws a code 20 but i swapped out the fuse box and still same code and same problem.
checked all fuses everywhere.
checked all grounds and even added a few more.
tried two different pm6's and still no spark.
at my wits end, please help.
Old Jun 14, 2007 | 05:33 PM
93formula's Avatar
well figured it out, changed distributors and back to the pm6 fired right up. weird, not sure why the zc ecu caused that to happen but im not about to find out.
P1_Variable
22
Mar 1, 2009 05:28 PM
jfields06
Dec 26, 2008 07:04 PM
zcrxt
11
Jul 31, 2006 01:29 PM
Jowee
Feb 17, 2005 01:06 PM
KimChiKid
Aug 10, 2003 05:37 AM
