Head Gasket problem?
Old Jun 14, 2007 | 06:41 AM
fluk3d's Avatar
Default Head Gasket problem?
I have been leaking a crazy amount of oil right above my manifold in the corner. I am wondering if this could be a blown head gasket.
thanks for your help
Old Jun 14, 2007 | 07:22 AM
SOHC IT's Avatar
Default Re: Head Gasket problem? (fluk3d)
If it is just an oil leak and you are not leaking compression it may not be blown. I would try retightneing you head bolts and see if that helps. What engine combination are you running? Maybe you have the wrong gasket and it is not allow the passage of oil through thus creating the leak.
Old Jun 14, 2007 | 08:14 AM
fluk3d's Avatar
Default Re: Head Gasket problem? (SOHC IT)
I'm running a b18a1. I just finished doing a compression test here are the results
1 181
2 179
3 182
4 180
I am running a gt25r at 9psi. I'll try re-tighting the head bolts to see if that helps.
Old Jun 14, 2007 | 08:18 AM
SOHC IT's Avatar
Compression looks to be in range. I would bet you need to retorque. Did it leak the whole time it was installed? What type of gasket are you running?
Old Jun 14, 2007 | 08:36 AM
fluk3d's Avatar
i'm running the oem gasket. It just started happening after putting on a new valve cover and gasket that's whats odd about this situation. I guess they get loose over time
Old Jun 14, 2007 | 09:18 AM
WrongWD's Avatar
the exact same thing has been happening to me. i'm not boosted though, but my compression numbers look almost identical to yours. just because i'm paranoid though, i'll be replacing the head gasket and the bolts with studs in a few weeks.
Old Jun 14, 2007 | 09:57 AM
fluk3d's Avatar
Default Re: (WrongWD)
I'm going to re-torque the head studs tomorrow morning, should I re-torque them to 61 lb-ft? any tips before I start?
Modified by fluk3d at 2:19 PM 6/14/2007
Old Jun 14, 2007 | 11:36 AM
hitekper4mance's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fluk3d &raquo;</TD></TR><TR><TD CLASS="quote">I have been leaking a crazy amount of oil right above my manifold in the corner. I am wondering if this could be a blown head gasket.
thanks for your help</TD></TR></TABLE>
just out of curiousity... I am not a mechanic and I know ANYTHING is possible but, why would you ask about a blown head gasket if it is leaking at the valve cover, wouldnt it be the valve cover gasket??
Old Jun 14, 2007 | 11:46 AM
fluk3d's Avatar
Default Re: Head Gasket problem? (hitekper4mance)
it's not my valve cover gasket leaking, that's been replaced along with the o-rings when I got the new valve cover. It's leaking right below it, on the corner of the block. It's hard to tell from the pic sorry about that.
jdmitrdc2
Apr 15, 2009 11:31 AM
boostedjdmdc2
Jan 13, 2009 10:49 AM
allmotorsi04
Apr 3, 2006 07:36 PM
spidermancivic
Mar 5, 2006 11:12 AM
Mr. Thunderlips
Nov 8, 2002 05:25 PM
