No Brake lights or Horn - Fuse is good - 92 dx manual swap
a while ago when I was still getting my car to run right in the garage, I noticed my horn didn't work. But I didn't really care, I figured 15 years was its life span.
Last night when I was finally able to drive the car on the road, I noticed that I didn't have any brake lights.
The tail lights light up when I turn the lights on, but they don't get brighter when I hit the brakes, and the 3rd brake light does not light up. I looked at the brake light switch by the pedal and it is working.
The horn and brake lights share a fuse in the underhood fuse box, that fuse is good.
I'm not sure what the problem could be.
My car is gutted, no heater, no climate controls, no radio (for now- silence gets old) And has also been converted from auto to 5 speed.
Is there a chance that I need something (like the auto interlock box for example) to make the things on that fuse work?
Sort of like how the turn signals go through the hazard light switch and they won't work if you don't have that switch hooked up?
The interlock box (small blue box that auto civics have, mounts where the clutch pedal would be and allows you to remove your key when in Park) was my first thought because you have to have your foot on the brake when you put your auto car in Park to take the key out.
bulbs probably are blown...dead...
wire for the horn might have a break in it...find it and fix it...
that is all i can think of...since you say that the fuses are good and all...
good luck...
good luck...
99civic4dr
May 25, 2012 02:04 PM
CrazyRexBoy
Jan 13, 2007 07:14 PM
jah_fyah
Jul 8, 2006 10:27 AM
b16a2pwr
Feb 14, 2004 02:28 PM
