New bearings and crank question
Old Jun 13, 2007 | 10:44 AM
imptricer's Avatar
Default New bearings and crank question
i just installed new bearings and had my crank ground .10 under and i plastigauged it all they were in spec by .0015 and .002. i used rolay purple assembly lube and when i go to turn the crank over by hand its harder than it should be once you get it turning its easy but when you stop for 5 min and try to spin it again its hard???? i pulled each bearing off and checked them all looked good! torque specs are correct i have no clue to why this would be happening can anyone help
gdrum
Apr 6, 2017 06:57 AM
killsnake562
May 16, 2009 08:28 AM
krhagon
Mar 31, 2008 02:46 AM
krhagon
Mar 29, 2008 05:17 PM
swatteamtimmah
Apr 4, 2006 10:02 PM
