Cant get driver side axle to lock in help!
Old Jun 13, 2007 | 04:58 AM
1993DXcivic's Avatar
Default Cant get driver side axle to lock in help!
I cant get the driver side axle to lock into the trani after doing a automatic to manual trani swap. Axle slides in but not all the way? Ive tried 3 different axles and no luck! Im using a d-series EX/Si trani with new stock axles. I know its not the axle but can the receiver in the trani go bad? It feels like the axle locks but then I can pull it out by hand. Passanger side is good. any help would be awsome...
Old Jun 13, 2007 | 05:28 AM
92_civic's Avatar
Default Re: Cant get driver side axle to lock in help! (1993DXcivic)
no chance a c-clip popped off and is blocking the axle from seating? if not have you tried pushing the axle towards the trans (to take up the slack in it) and lightly tapping it with a medium hammer to try and seat it?
Old Jun 13, 2007 | 11:50 AM
Default Re: Cant get driver side axle to lock in help! (92_civic)
Im going to remove the axle and see if the old c clip stayed in the trani. I got the trani used and I never checked! the passanger side goes in fine a locks perfect. Its just driver side giving me problems. Some dude was telling me that I might have a del sol /si trani that requires a half shaft but im not too sure on that issue...
Old Jun 19, 2007 | 08:20 AM
92_civic's Avatar
it should only need a half shaft if it was a b series trans...I think you would have figured that out by now if that was the problem
have you figured it out yet?
OmgDelSol
Sep 10, 2014 02:16 PM
integrainside
Transmission & Drivetrain
Oct 3, 2013 05:21 PM
ralphieg
Oct 2, 2012 06:36 PM
wu tang
14
Dec 17, 2007 09:23 AM
ill phil
May 15, 2003 06:27 PM
