What tool to cut fender for side markers?
Old Jun 12, 2007 | 08:56 PM
r3sgtec's Avatar
Default What tool to cut fender for side markers?
I want to install side markers on my eg. looking at the sidemarkers/templates, i need to cut a rectangle out of my fenders. I was wonder what tool i would use to do this. Im looking for like a dremel like thing with a wheel that cuts into metal, such as a fender, as i would need this tool for many other uses. ive had dremel tools in the past and they are a piece of ****, no power and the bits always broke, like the sanding ones and ****. Any suggestions?
Old Jun 12, 2007 | 09:02 PM
truevietluv636's Avatar
Default Re: What tool to cut fender for side markers? (r3sgtec)
i used a craftsman professional all in one cutting tool... cuts mostly any **** i could find if i use the right discs. http://www.sears.com/sr/javasr...e=Yes
Old Jun 12, 2007 | 09:19 PM
laocivic's Avatar
Default Re: What tool to cut fender for side markers? (truevietluv636)
i used a metal cutting wheel w/ my dremel n had no probs
Old Jun 12, 2007 | 09:20 PM
cxSHOE's Avatar
i cant recall what the name of it is, but this is what you should be using to cut or make nice straight cuts on thin metal. if anyone knows what the name is let me know. i havent used it for years, hence cant recall what the name is.. LOL
you make a hole in the center of your sidemarker outline and then you stick the tip in and start cutting the metal out to the lines of your outline. it cuts small square cuts. it will not chip the paint... atleast when i used it years ago it never did. and when it cuts its very smooth and cuts easily and no strain on the fingers.
if you want it i can sell it aswell since i do not need it...
sorry if the photos are too big...
Old Jun 12, 2007 | 09:26 PM
92hatch_cx-t's Avatar
i just used a cut-off wheel GL
Old Jun 12, 2007 | 09:27 PM
ke98248's Avatar
Default Re: (92hatch_cx-t)
dremel ftw
Old Jun 12, 2007 | 09:31 PM
CapnKrunch's Avatar
I had to cut a hole for for my sidemarker light in my replacement fender with a dremel and a drill. It took me 6 hours. It was the most painful 6 hours of my life....
Old Jun 12, 2007 | 09:34 PM
highrev1987's Avatar
Default Re: What tool to cut fender for side markers? (CapnKrunch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CapnKrunch &raquo;</TD></TR><TR><TD CLASS="quote">I had to cut a hole for for my sidemarker light in my replacement fender with a dremel and a drill. It took me 6 hours. It was the most painful 6 hours of my life.... </TD></TR></TABLE>
its not that hard, try doing something thats more challenging like suspension work or a tranny rebuild
Old Jun 12, 2007 | 09:35 PM
B16Power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r3sgtec &raquo;</TD></TR><TR><TD CLASS="quote">I want to install side markers on my eg. looking at the sidemarkers/templates, i need to cut a rectangle out of my fenders. I was wonder what tool i would use to do this. Im looking for like a dremel like thing with a wheel that cuts into metal, such as a fender, as i would need this tool for many other uses. ive had dremel tools in the past and they are a piece of ****, no power and the bits always broke, like the sanding ones and ****. Any suggestions?</TD></TR></TABLE>
Let me know if this helps you out any.
http://forums.clubsi.com/ubbth...age/1
Old Jun 12, 2007 | 09:41 PM
EM1SON's Avatar
Default Re: What tool to cut fender for side markers? (cxSHOE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE &raquo;</TD></TR><TR><TD CLASS="quote">i cant recall what the name of it is, but this is what you should be using to cut or make nice straight cuts on thin metal. if anyone knows what the name is let me know. i havent used it for years, hence cant recall what the name is.. LOL </TD></TR></TABLE>
Its called a metal nibbler.
Old Jun 12, 2007 | 10:23 PM
Richard...'s Avatar
Default Re: What tool to cut fender for side markers? (lesturrr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lesturrr &raquo;</TD></TR><TR><TD CLASS="quote">
Its called a metal nibbler. </TD></TR></TABLE>
why not just get some from password:jdm
Old Jun 12, 2007 | 10:29 PM
My_EFsedan's Avatar
Default Re: What tool to cut fender for side markers? (richard7968)
i used a dremal with a disc..worked great. local store ftw
Old Jun 12, 2007 | 11:08 PM
r3sgtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richard7968 &raquo;</TD></TR><TR><TD CLASS="quote">why not just get some from password:jdm </TD></TR></TABLE>
or, i could save my self $167.00 and just use my own fenders...
Old Jun 12, 2007 | 11:09 PM
r3sgtec's Avatar
Default Re: What tool to cut fender for side markers? (B16Power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Power &raquo;</TD></TR><TR><TD CLASS="quote">Let me know if this helps you out any.
http://forums.clubsi.com/ubbth...age/1</TD></TR></TABLE>
thanks alot, ill probably end up doing it this way.
Old Jun 12, 2007 | 11:12 PM
r3sgtec's Avatar
i also have to cut a hole behind the fender, on the frame part, just below the door/ window sil because i tried installing a new antenna and it got jammed on that corner and ive tried everthing so far, so i figure this is the only way. is there a cutting tool that will cut that thick of metal?
Old Jun 12, 2007 | 11:13 PM
cxSHOE's Avatar
ahhhhh there we go... thanks
Old Jun 12, 2007 | 11:19 PM
cxSHOE's Avatar
thanks alot, ill probably end up doing it this way.</TD></TR></TABLE>
let me know if your going to use the nibbler. $10 shipped. it really is easy and you can make straight clean cuts.
Richard...'s Avatar
Old Jun 12, 2007 | 11:22 PM
alacard's Avatar
sounds to me like using the metal nibbler would be a lot easier than the dremel i used for mine...everyone who used it seems to have had no problems...my sidemarker install was a pain in the ***. haha.
94 Civic Si
14
May 30, 2018 10:44 AM
kcari
Paint and Body
Oct 5, 2008 12:35 PM
mr nut
Jul 10, 2007 11:50 AM
JustinL
Welding / Fabrication
May 27, 2005 02:53 AM
bLuEciVicGuY
Mar 3, 2003 07:02 PM
