Wiring doubt that anyone knows
Old Jun 12, 2007 | 05:48 PM
hatch b16a guy's Avatar
Default Wiring doubt that anyone knows
I have a 92 cx hatch my wiring harness by the shock tower battery side which would by the right has a wire that got caught and riped off. It is not the first connector that is up at the top it is the next one that is about the same size as the first one that is at the top. The wire appears to be yellow and red. Any help would be great
Old Jun 12, 2007 | 05:51 PM
saveacivic's Avatar
who's got a haynes manual for yellow/red?....
Old Jun 12, 2007 | 06:02 PM
Luserkid's Avatar
Default Re: (saveacivic)
Yel/red could be a few things, one is oil pressure sensor (back of the block for the dummy light) If you have the other end just follow the line to where it goes.
Old Jun 12, 2007 | 06:12 PM
NOFX's Avatar
H-T White Ops
I wish I could help, but I'm not exactly sure what I'm looking at here.
Old Jun 12, 2007 | 07:59 PM
Default Re: Wiring doubt that anyone knows (hatch b16a guy)
Sorry I know the pics are not the best and I am probadly describing it really bad lol. Ok on the right side there are the three connectors that you plug you harness into well it is not the first one that is at the top and is bolted to that clip it is the second one and it is pretty good size almost the same size as the first one. Anyways one of the wires must have caught are something and riped it is yellow and red. I tried to follow it into the harness but I cant find it because it splits into two big wires that are combined. I was just wanting to know what it was and what would it affect my main worry is that my vtec wont engauge maybe because it is a oil pressure wire? Any help would be great and if you guys need any more info I can try to explain it thanks alot guys
Old Jun 12, 2007 | 08:02 PM
Btw if it is the oil pressure will i need that for vtec and if so can someone help me out with the location of the pin out on a p72 obd1 ecu so I can just wire it
unix4linux
Audio / Security / Video
May 12, 2008 06:07 AM
MooJenLude
Aug 2, 2007 05:50 AM
Neren
15
Oct 5, 2005 05:56 PM
dreweg
Jul 7, 2003 03:48 AM
