Wiring doubt that anyone knows
I have a 92 cx hatch my wiring harness by the shock tower battery side which would by the right has a wire that got caught and riped off. It is not the first connector that is up at the top it is the next one that is about the same size as the first one that is at the top. The wire appears to be yellow and red. Any help would be great
Re: (saveacivic)
Yel/red could be a few things, one is oil pressure sensor (back of the block for the dummy light) If you have the other end just follow the line to where it goes.
Re: Wiring doubt that anyone knows (hatch b16a guy)
Sorry I know the pics are not the best and I am probadly describing it really bad lol. Ok on the right side there are the three connectors that you plug you harness into well it is not the first one that is at the top and is bolted to that clip it is the second one and it is pretty good size almost the same size as the first one. Anyways one of the wires must have caught are something and riped it is yellow and red. I tried to follow it into the harness but I cant find it because it splits into two big wires that are combined. I was just wanting to know what it was and what would it affect my main worry is that my vtec wont engauge maybe because it is a oil pressure wire? Any help would be great and if you guys need any more info I can try to explain it thanks alot guys
Btw if it is the oil pressure will i need that for vtec and if so can someone help me out with the location of the pin out on a p72 obd1 ecu so I can just wire it
dreweg
07-07-2003 03:48 AM
