Lower ball joint 93 prelude
during my transmission swap the driver side lower ball joint got broken (the boot) and grease started pouring out. I had one of those fork tools and it still broke. Anyway, i called honda and they don't sell them seperately. Only with the control arm for 375 dollars, expletive that. i called napa and they said 80 dollars but i have to install it into the control arm. I called a few shops and even though its a 5 min install at most they want 1 hour of labour which is 83 dollars, lowest i could get from a reputable shop. the guy at napa said that if the wheel is off and the car is on jack stands i can use a jack to push it into the control arm. Will this work or destroy the ball joint? anybody have any answers on how to install it properly? i was told you can buy a tool to help but its 200 some dollars whicih defeats the purpose of me saving money. thanks in advance.
i just read a write up and it looks like i am just going to pay 83 dollars. its worth piece of mind that its not going to break on me. Am i goign to need to get an alignment done after this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prudz_lude »</TD></TR><TR><TD CLASS="quote">Am i goign to need to get an alignment done after this?</TD></TR></TABLE>
For replacing the lower ball joint? No. You didn't really change the geometry of your suspension like drop springs or such.
if i rent a ball joint press what are the chances i destroy the ball joint? is it easy to do? the suspension is already all out and i am mechanically inclined. i just have no clue how hard it is to install this correctly.
Sorry i should clarify the ball joint in the suspsension right now is blown. I will be pressing a new one in and i don't want to destroy it.
CuttingEdge SI
10
Jan 24, 2005 01:32 AM
