Dpfi to odb1 Ls wiring question
Ok before you guys start saying use the search methond I did and this is what I found.
https://honda-tech.com/zerothread?id=1814292
https://honda-tech.com/zerothread?id=1797137
I have a the following that I plan on putting in a 88 crx dx:
B18a obd0 (I believe)
LS odb1 wiring harness
LS odb1 distributor
89 CRX Hf resistor box
p75 odb 1 ecu
#1 If I by the boomslang dpfi to odb1 conversion could I just use the LS wiring harness and plice the wires? Or will i still need to get a SI/Hf wiring harness?
#2 Will the stock injectors work or will I need to use the resistor box?
I need to know as soon as possible. I'm trying to have this up and running for the meet on the 23rd. Any help will be plentiful. Thank you.
LS odb1 distributor
p75 odb 1 ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90ed6 »</TD></TR><TR><TD CLASS="quote">you cant use any other harness but the one on the car. you have to make it work.
and you dont need a resistior box for obd1 injectors.</TD></TR></TABLE>
So you are saying I cant you use this http://www.boomslang.us/obd0to1.htm and use the LS engine harness connectors? I have to do a mpfi conversion and then a LS wirng conversion.
dx = 2 injectors
LS = 4 injectors
the slang will work, but you still have to modify your dx wire harness for the extra injectors, when you have completed it, you will have 2-3 extra plugs.(DX has some plugs that are not needed for mpfi)
http://www.rywire.com are going to do my engine harness, and obd1 conversion for my B16a swap soon as i get my B16a. $300 but well worth it imho. They know their wiring, and I suck at it. better them doing it for me, than me doing it for myself.
LS = 4 injectors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma »</TD></TR><TR><TD CLASS="quote">odb = ol' dirty bastard (RIP)
obd = onboard diagnostics
and yes you need to wire up a 4-wire oxygen sensor when you convert to obd1</TD></TR></TABLE>
Damn. I thought I was so close to being done too. Well I went online to see where it would be and I found out that there is in Integra nearby that my have one. If it is an OBDII would could I use that O2 if not. Could I pinch one from an OBD1 civic instead?
i'd prefer to get a new one, but that's my preference. Some don't mind getting used ones. they are not that expensive. considering how long they should last.
Buy it and forget about it for 5+ years.
xXhellxraiserXx
Jan 15, 2012 10:23 AM
xxstuntin4life
Oct 15, 2009 02:12 PM
ivanson
Nov 5, 2005 06:00 PM
