Have some questions about knock sensors and what this plug goes to?????
Old Jun 12, 2007 | 06:18 AM
CBURKE's Avatar
Default Have some questions about knock sensors and what this plug goes to?????
I found that my knock sensor was never hooked up and I am getting a code 23. I wired one up and plugged it into the broken one I have in the block and the car would not rev past 4k.
There is a loud ticking coming from that area, and I was thinking maybe the knock sensor is not able to get rid of it so that is why I can here it.
I thought it was a valve so I checked them all and checked the lash and there fine. It also does not tick all the time, and if you rev it and it was the valves smacking you would here it.
I also have this plug left over and no home LMK if you know what it is????
Old Jun 12, 2007 | 06:32 AM
mr.speaker's Avatar
Default Re: Have some questions about knock sensors and what this plug goes to????? (CBURKE)
Yeah the car is probably in limp mode from the knock sensor,that's normal..Sometimes you can just reset the ecu and it'll rev back up to normal rpm with the cel still on..
That plug looks like intake air tempurature ..i forget the colors i think they're are red/yellow green/white or green/cream
edit- actually i dont think thats the iat, mine looks different
Old Jun 12, 2007 | 06:56 AM
CBURKE's Avatar
it's blue and black?
But I need to know if the knock being bad can cause ticking?
Old Jun 12, 2007 | 07:18 AM
mr.speaker's Avatar
Default Re: (CBURKE)
Ok i just looked at my harness that's the fast idle valve ,you don't need it
But i dont see why the bad knock sensor would cause ticking..Unless it's causing timing to be retarded severely,,maybe just leave it unplugged like before untill you can get a new one.......Or if you dont mind being ghetto you could ground the wire out so the ecu thinks it's hooked and doesn't throw a code.
Old Jun 12, 2007 | 07:21 AM
ChickenH's Avatar
That plug u dont need on a b swap. if the knock sensor is bad or not hooked up it retards timing so it will hardly run.
Old Jun 12, 2007 | 07:24 AM
CBURKE's Avatar
It's not running real good, but it does run.
Here is a vid, kinda dark but at the end you can kinda hear it.
Modified by CBURKE at 10:21 AM 6/12/2007
Old Jun 12, 2007 | 07:32 AM
CBURKE's Avatar
Would you just ground the wire comeing from the ecu or from the knock?
I took care of the other 2 codes 22 and 17
Old Jun 12, 2007 | 07:58 AM
Furyof4's Avatar
There is no possible way a faulty knock sensor will cause a "ticking noise.
Check your LMA's.
Old Jun 12, 2007 | 08:08 AM
CBURKE's Avatar
I did not think of that, will do thanks.
On grounding out the knock do I ground it from the ECU?
Old Jun 12, 2007 | 12:01 PM
CBURKE's Avatar
TTT
Old Jun 12, 2007 | 01:28 PM
abnaasefmb's Avatar
More than likely the ticking is your injectors. All of my engines have made a ticking noise around the intake manifold. I even went so far as to replace the lma’s with the h22 ones (used the shim) and even with a new build it still ticks.
Old Jun 13, 2007 | 05:27 AM
CBURKE's Avatar
Is it pretty loud? Mine in not all the time it tick then goes away, then starts ticking again.
Old Jun 13, 2007 | 05:43 AM
mr.speaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE &raquo;</TD></TR><TR><TD CLASS="quote">Is it pretty loud? Mine in not all the time it tick then goes away, then starts ticking again.</TD></TR></TABLE>
my injectors are sometimes like that..loud when cold,then it goes away,,then comes back........You really just have to put your ear right on the injectors to make sure it's them
and about the knock sensor grounding..What has worked for me is hooking up the wire to the knock sensor like normal,,but take it out of the block and ground the actual sensor....If you just ground the wire it won't work,,or it might work for a while but the ecu will not see changing current and probably throw a cel...
Old Jun 13, 2007 | 08:28 AM
LilJonWask's Avatar
grounding it won't do anything. either buy a new one or this: https://honda-tech.com/zerothread?id=1181854
Old Jun 13, 2007 | 10:25 AM
CBURKE's Avatar
I am chipping it away.
paz_honda
Honda CR-V & Element
Nov 22, 2017 09:16 AM
Hatch_Back_97
Aug 29, 2006 10:45 AM
BlueShadow
Jul 20, 2005 12:24 PM
T_Rex
Feb 3, 2003 07:43 PM
