CEL... I think !?!? ( Video inside )
Old Jun 12, 2007 | 03:06 AM
uneek360's Avatar
Default CEL... I think !?!? ( Video inside )
Ok, so my SRS light has been on for awhile never thought anything of it till now when i tried to see if im getting codes and got the following :
someone before must have messed the **** but i believe im getting :
92 EVAP Solenoid/Valve/Vacuum Lines
Any quick fixes ?? Im searching as i right this
Quick note : It idles right around 1k, i have noticed that while it's warming up it sometimes dips to about 100 rpms but when i drive it's good.
Thanks
Old Jun 12, 2007 | 04:45 AM
uneek360's Avatar
bump
Old Jun 12, 2007 | 06:05 AM
uneek360's Avatar
Default Re: (uneek360)
Can anybody tell me where is this soleniod ??? Also should i worry ??
Old Jun 12, 2007 | 07:24 AM
jayjay's Avatar
That is not a CEL (Check Engine Light). That is your SRS light. It's flashing to tell you there is a fault in your system.
go here:
https://honda-tech.com/zerothread?id=264288
Old Jun 12, 2007 | 07:28 AM
uneek360's Avatar
Default Re: (jayjay)
so it's flashes when i jumped the plug exactly the way the CEL is supposed to but it's not a code ?? Nine long flashes and Two short flashes ??
Old Jun 12, 2007 | 07:29 AM
Luserkid's Avatar
On another note in the video your CEL never turns on. Does it ever turn on when the cars in the ON position?
Old Jun 12, 2007 | 07:31 AM
uneek360's Avatar
Default Re: (Luserkid)
no the CEL never comes on, it seems that someone fu%ked with it before i got the car... The SRS light is always on and when i jump the Jumper plug the SRS light is the one that flashes.
Old Jun 12, 2007 | 08:36 AM
uneek360's Avatar
so can anybody tell me where's dat purge control soleniod ?? Do i need it ?? Anything ??
Old Jun 12, 2007 | 09:55 AM
Luserkid's Avatar
When you turn your car to ON position does the SRS come on then turn off then back on solid? If so then i think someone changed the SRS to be the CEL.
The purge control solenoid is for emissions. What motor/ecu are you using?
Old Jun 12, 2007 | 10:22 AM
uneek360's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">When you turn your car to ON position does the SRS come on then turn off then back on solid? </TD></TR></TABLE>
Yea is does.... I have a 95 B18C right now using a p28
Old Jun 12, 2007 | 10:26 AM
Luserkid's Avatar
If your using a P28 (chipped right?) it wont be looking for a code 92. Try resetting the ecu and see if the SRS stays off when you turn it to the ON position without starting the car.
Old Jun 12, 2007 | 02:17 PM
commotion's Avatar
is it possable that somone switched somthing in the back of your dash cluster? im just givin you ideas. cause i never saw the back of my cluster.
streethondar
May 10, 2015 07:12 PM
TouringAccord
Oct 12, 2004 07:20 AM
beeroh
Sep 26, 2004 02:54 AM
civickidd99
Aug 14, 2003 08:29 PM
zelifcam
Oct 18, 2002 11:25 AM
