gsr cam question
I have a gsr engine that I'm going to build for higher boost and power next summer or so.
I've been doing searching and reading and from what I've read, a lot of people recommend either GSR or TYPE R cams in a turbo setup.
If I wanted to use my gsr cams, how high would I be able to rev assuming I have a fully built head? (port and polish, valves, valvesprings, retainers, all that jazz)
About when will they stop making power?
I would wait and see how the tune goes, but if I need to upgrade, I'd rather be able to upgrade them before I finish assembling everything.
I plan on around 400 whp. Would prefer a higher redline, maybe 9500-10k.
I dont wanna have to shift into 5th If I dont have to if going down the 1/4 strip.
I did some searching, couldnt find anything about gsr cams max rpm on a built head, only on a nonbuilt.
Ill have a chipped p28, so no rev limiter.
Thanks everyone.
Thanks everyone.
on my built b16, gsr cams, my peak power was 9800. it was still making a little power that high, just didnt want to kill it, wanted to have some fun. no anti lag launching at 8200, shifting 94-9600. trapping 8800ish? made 540 wheel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">on my built b16, gsr cams, my peak power was 9800. it was still making a little power that high, just didnt want to kill it, wanted to have some fun. no anti lag launching at 8200, shifting 94-9600. trapping 8800ish? made 540 wheel.</TD></TR></TABLE>
Wow, that's pretty impressive that the GSR cams still made power that high up!!
Sounds like the GSR cam's will be just fine. If money isn't a thing for you and you reeeeally want to make some serious power all throughout the powerband, get some Buddy Club Spec III cams--perfect for turbo, smooth as butter, and DAMN do they pull!
wasnt really pulling hard up there, but where we let off is where the peak was. remember, it was a little b16. he hee. and 28 si from a t3t67ho kinda helped a little he hee.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">wasnt really pulling hard up there, but where we let off is where the peak was. remember, it was a little b16. he hee. and 28 si from a t3t67ho kinda helped a little he hee. </TD></TR></TABLE>
Yeah, I thought about it more, and it's a wise decision not to rag on it too high up there in the RPM range. That's a lot of PSI, RPM, and HP on a liiiiittle block, so it's smart not to push it!
A true Vet always knows his cars limits!
1.8T_EG
Aug 19, 2003 05:58 PM
