90-91 vs 92-93 head question
Old Jun 4, 2002 | 07:24 PM
xxplosif1's Avatar
Default 90-91 vs 92-93 head question
I'm building my LS. I can get this 91 LS head for really cheap and its in good shape (mine has a lot of milleage on it). I'm planning to get 404's cam with springs and retainers. Since my car is a 92 RS, would it be better to get a 92-93 head or the 90-91 will do the exact same thing? I just don't wanna lose power cause of the head. I've heard that 90-91 and 92-3 head are different but never knew what was different exactly....is this true?
thanks!
[Modified by xxplosif1, 4:25 AM 6/5/2002]
Old Jun 4, 2002 | 07:31 PM
TegR's Avatar
Default Re: 90-91 vs 92-93 head question (xxplosif1)
the intake mani is different. are you looking for performance or just rebuilding for reliablity
Old Jun 4, 2002 | 07:35 PM
xxplosif1's Avatar
Default Re: 90-91 vs 92-93 head question (TegR)
I'm getting the head only, no cams, no springs....nothing. I'll be keeping my intake manifold....and yes, i'm looking for performance (crower cams)
I'm just getting the new head so then i'll be able to build it until its ready, and then swap it on my current block.
Old Jun 4, 2002 | 07:38 PM
TegR's Avatar
well how much are you thinking of spending?
Old Jun 4, 2002 | 07:40 PM
xxplosif1's Avatar
I'm just getting the 404 cams, springs and retainers. This built head will go on my current block. There's nothing else i'll do for this summer.
[Modified by xxplosif1, 4:41 AM 6/5/2002]
Old Jun 4, 2002 | 07:51 PM
TegR's Avatar
don't get a head thats cheap cause you don't know what condition its in. i'd get a head from jg dynamics. there are really good, the run around $700-$1300. its your choice.
Old Jun 5, 2002 | 05:27 AM
xxplosif1's Avatar
I know that tegR. Thats not what i asked for.
anyone eles?
Old Jun 5, 2002 | 12:36 PM
real9999's Avatar
Your going to be losing power with both those heads. Although they can work, 404 cams aren't quite at home without a ported head. If your hell bent on running them stock, however, make sure that the head is in spec. The year it comes from won't be significant.
Tom
Old Jun 5, 2002 | 01:17 PM
primoEF's Avatar
Default Re: 90-91 vs 92-93 head question (real9999)
The heads are all the same, even a 99 CRV head will bolt right on your block, thats what I am doing to mine, you should PnP the head when you have time since you are running with 404s
Old Jun 5, 2002 | 04:43 PM
teg92's Avatar
TegR: Do you have pics or details or dyno charts of your setup? Is that streetable?
Old Jun 5, 2002 | 05:02 PM
xxplosif1's Avatar
thanks. I know a PnP would be nice but not for now, can't afford it this summer. I'm sure the 404's will make nice power even without a PnP....i won't get the max outta of the cams but still...
Remember HX_guy? If i remember he had a stock head when he used to have his old LS set up. Anyway, can't be worse than what i have right now
Old Jun 6, 2002 | 04:22 AM
TegR's Avatar
Default Re: 90-91 vs 92-93 head question (teg92)
yeah its streetable, i run 8psi for dailydriven purposes. but on the track i run 26psi with 116octane.
Snailor Built
Sep 15, 2009 08:34 AM
FinedTuned
Jun 25, 2009 06:19 PM
ej2_sir
Apr 21, 2006 01:19 AM
EpeK
Sep 19, 2002 09:45 AM
Speedz
Feb 10, 2002 11:15 PM
