zc ecu headach
hello i have a 1993 civic SI with a zc in it ! we currently have a p28 ecu wich is the stock one ... wich ecu should we use for the zc to work best ! do we have to go to obd0 or can we use an obd1 ecu ? does the p28 make it run ok ? im sorry this is a easy question i just need someone to tell me what to do ! thanks !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectpd »</TD></TR><TR><TD CLASS="quote">sorry it is the dohc ZC its not vtec</TD></TR></TABLE>
oh, then you need to either get the one you have chipped/tuned, or get the appropriate ecu.
Though I can see why it would run okay on the dohc zc.
the car is running ok with a p28 we just wana put the right ecu in so we can get the potential out of the zc ! would you know wich obd1 ecu run a zc without the vtec ?
Because that's another SOHC ecu. It's non-vtec, but you'll still not be getting the "potential" you want out of the DOHC ZC until you get the DOHC ZC ECU or ECU maps.
LorenGeist
Aug 14, 2004 03:01 PM
