Problem with gaskets for my f20b
Old Jun 11, 2007 | 09:59 AM
HeikDiesel's Avatar
Default Problem with gaskets for my f20b
I removed my balance shafts so now I need to replace a few gaskets and seals. I need the two o-rings behind the oil pump housing, the o-ring for the balance shaft drive housing, pickup tube gasket, oil pan gasket if there is one, and the o-ring that sits in the block girdle for #3 main cap. Any help fellas? 98 prelude sh lists most of the parts in the picture but no part number
Old Jun 11, 2007 | 10:28 AM
Bense's Avatar
Default Re: Problem with gaskets for my f20b (HeikDiesel)
what picture are you looking at?
your best bet is to go to hondapartsdeals.com and browse parts for the 97-01 prelude h22a4 and the 98-02 accord F23. If you're using the firefox web browser, which I highly reccomend, right click on that pop up, select "copy image location"
Then open up a new browser window and paste that location into the address bar and you'll have a much higher resolution image to browse from.
http://getfirefox.com for the browser
http://hondapartsdeals.com
Old Jun 11, 2007 | 10:36 AM
HeikDiesel's Avatar
Default Re: Problem with gaskets for my f20b (Bense)
Ok i did 98 prelude sh....this is the block and pan group. I need numbers 46, 13 (which gives a part number for) and a pan gasket which I dont see a number for
Same car but oil strainer group I need numbers 4, 5, 9(numbers listed) 31,
So basically I really only need help on 46 and 31 and a pan gasket if needed. I think thats all I need to replace for now?
Old Jun 11, 2007 | 10:40 AM
Bense's Avatar
don't do the sh, the block is weird on that thing
Old Jun 11, 2007 | 10:42 AM
Bense's Avatar
98 prelude base engine cylinder block
98 prelude base engine oil pump
Old Jun 11, 2007 | 10:45 AM
HeikDiesel's Avatar
cool well the non sh helped with 46 but i still dont get a part number for that o-ring (31)
Old Jun 11, 2007 | 10:49 AM
Bense's Avatar
oh yeah i see that for #31. It's prob not listed but will prob interchagne with the f22 and f23 models
Old Jun 11, 2007 | 10:55 AM
HeikDiesel's Avatar
ok so i found 31. 1996 prelude si vtec model, its number 32 in the diagram. Thanks for your help bense. Ill post part numbers as soon as I know for sure they are the right ones
tamboo
Oct 23, 2018 11:29 AM
Inextricabledrvr
May 15, 2009 08:03 PM
93sivtec
Oct 7, 2007 04:24 AM
hybrid_vtec
Feb 7, 2005 06:53 AM
Chaze*R
Apr 8, 2003 06:56 AM
