Got my new intercooler mounted and got the radiator back up to the front. Fab pics inside
I got my new intercooler mounted up on Sat. The car is just a drag car so it sees about 30 seconds of on time ever 90 minutes.
http://drag.nickslife.net/?page_id=38
Got the initial Dyno Results in as well. *** June 17, 2007 ***
My 632 Low Boost Dyno Vid
Modified by Nick@JEPistons at 7:26 AM 6/19/2007
Modified by Nick@JEPistons at 7:27 AM 6/19/2007
Modified by Nick@JEPistons at 7:28 AM 6/19/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA »</TD></TR><TR><TD CLASS="quote">is that thing automatic ????</TD></TR></TABLE>
last time i seen it. yes
Did you have any problems with bleeding the air out of the cooling system with that top-mount radiator? I would imagine having a radiator completely flat like that you would get air trapped in the corners of the end tanks, especially without any air seperator and seeing how the oem setup has one (I imagine since the motor is a flat 4 and would have some problems trapping air because of the layout). New setup does look bitchin.
do you have an undercar picture? Looks pretty cool. What did you use to pump the oil back to the pan from the turbo?
