diy rear camber kit......
ok people say that you really don't need a rear camber kit, all you need is some washers, what are they talking about? washers where? I have an ej1 and have it slammed, I got a good camber kit in the front but now it's time to do the back, but people say use the washer trick, I have no idea what they are talking about, pics would really help
» Search Results
Your search for washer trick returned 55 results.
http://home.earthlink.net/~civ....html
https://honda-tech.com/zerothread?id=1465602
http://www.boltdepot.com/ErrNo....aspx
https://honda-tech.com/zerothread?id=1029302
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ ITO »</TD></TR><TR><TD CLASS="quote">hell yeah I just finished doing this right now lol</TD></TR></TABLE>
Did it work out for you?
What was the drop? How many washers did you use?
hell yeah, thats cheep. infact i have that stuff in my garage right now, but the $$ for an allignment i do not
but did yall see him off roading his coupe hahahah, and the burnouts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dannis. »</TD></TR><TR><TD CLASS="quote">haha. im sorry but that beginner driver sticker cracked me up.</TD></TR></TABLE>
yeah like I said "it's an old pic" that sticker was token off long time ago
» Search Results
The links posted is 7 years old, bound to be gone.
The washer trick is for rear camber not front. Hondas have adjustable camber in front, not the rear on these older cars.
https://www.google.ca/#q=honda+rear+camber+washer+trick
The clubcivic one had some info and some of the other links that google currently brings up may give you direction.
And since this rear camber thread got dredged up, lets see if we can get some current info in it.....
I've heard most of the "rear camber kits" you see on cheap-bay are garbage, they bind up or break being cheap lightweight aluminum etc.
Does anyone know who makes a strong high quality camber kit for 5th and 6th gen civics?
If I can find a good quality one, I wouldn't mind adding it to my hatchback just for added control.
yep,camber isn't adjustable from factory
and for the washer trick works great better then any cheap ebay ****
but u can't adjust -camber with it
and for the front tomorrow i'm gonna try to diy camber
btw is it better to have -camber? i don't care about the tires,i mean for stability
Oh okay, I just assumed the fronts were fully adjustable. That puts a damper on my tire wear issue on the front.
So looks like quality camber kit for the back and a high quality set of fully adjustabe upper control arms for the front are in order.
Thanks for the heads up, and thanks for the brands bswapped.
Looks decent turtle but doesn't say the material its made from, don't mind the weight of steel for the added durability.
Check out AMR camber kits if you are going for quality.
I've been running with the washer trick for years. It's great for degree or so, but any more than that and I would look into an adjustable arm.
