transmission problem
Old Jun 10, 2007 | 10:26 PM
1993gsrcivic's Avatar
Default transmission problem
anyone good wit a trans, they know what they are doing? i need the shaft replaced that hooks to the shift linkage it was bent on the highway by some junk in the road from the construction workers this is a gsr tran that was just rebuild so the gears are good that shaft is bent so it dont fully engage in 2nd 4th and rev
help
got money in hand
Old Jun 11, 2007 | 08:25 AM
Default Re: transmission problem (1993gsrcivic)
somebody know how to rebuild transmissions
Old Jun 11, 2007 | 10:07 AM
hitekper4mance's Avatar
u just need your shift rod replaced right?? I doubt it would be the transmission itself. U should be able to do it yourself.
Old Jun 11, 2007 | 09:14 PM
Default Re: transmission problem (hitekper4mance)
yea just the shift rod needs to be replaced but all the gears need to be out to get to it
Old Jun 12, 2007 | 08:36 AM
I cant see what you are looking at so I can not say for sure but... I highly doubt you damaged the inner portion of that tranny piece. probably just need to replace the piece from the tranny to your shifter. There's a rubber boot where the shift rod has a clip to expose the spring pin that you remove. I am assuming that you know this though. Just wanted to clarify that you need actually need tranny work.
Old Jun 12, 2007 | 10:30 PM
the piece the shift linkage hooks to, the little rod coming out of the trans is bent the shift linking is bolted to the trans wit a 12mm bolt and then it has a pin that needs to be banged out the piece that the pin goes in is bent that needs to be replaced
Old Jun 13, 2007 | 08:07 AM
crazy. looking at the stub that comes out the tranny. hard to believe it can be bent like that. Good luck finding someone to help you out. I am sure lots of people here can help with ideas and tech stuff... they have for me... but hands on in your area.
91grape
Sep 13, 2012 04:18 PM
patiencecali
Aug 26, 2012 07:18 PM
1kleenef
Jun 6, 2008 03:53 PM
Aespooncivic
May 7, 2005 09:23 PM
Shane54
Oct 11, 2003 08:53 PM
